You will have to do a hard reset...this will set it back to factory specs...you will loose any data that you have added to it...So be sure you absolutely cannot remember the password before you do this...
1...While holding the power button, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld. 2... Wait for the Palm Powered™ logo to appear, and then release the power button. 3... When you see the message that warns you about erasing all of the info on your handheld, do one of the following:
• Press Up on the 5-way navigator to finish the reset and show the touchscreen. • Press any other button to do a soft reset.
i can't access my list of pdf files. I need to delete some files but the application jumps from the...
(More)
i can't access my list of pdf files. I need to delete some files but the application jumps from the most recent pdf file I opened to the main menu
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the...
(More)
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the cable and reinstalled the software. Still will not talk to my computer. it keeps telling me to check my setup.
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back....
(More)
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back. I know the charger works because I checked it out with someone elses Palm.
