Question about HP OfficeJet 6110 All-In-One InkJet Printer
Paper Jam It keeps indicating that there is a paper jam but I can't find one. I have opened the backcover and done so much but to no avail. It will not take that message away and won't print.
  • HP Master
  • 19,396 Answers
Unplug both computer and printer from power.
Check the inside of printer for fragments of papers, open and close your printer's doors.
Eventually turn printer upside down and shake it gently to find out if there are foreign objects inside the printer.
If this does to help, try powercycling, removing and putting back cartridges.
If still no luck, then the printer is faulty.
Posted on Jan 30, 2009
I keep getting paper jam and load letter paper on my C544dn but yther eis no paper jam and there is a good amount of paper in the printer.
Take a look DEEP inside your printer. Sometimes all it takes is a tiny piece of paper to indicate a jam. Remove your printer cartridge(s), pull out your paper tray, open covers, etc. It is in there somewhere.
Nov 29, 2017 | The Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
I keep getting a paper jam 201 every time I print. Then I have to open it up and take out the cartridge. What is causing the paper to jam?
A 201 paper jam error indicates the paper did not reach the fuser sensor within the proper time period. This usually indicates the fuser has a problem and needs to be replaced. The part number for the fuser is 56P1333 and it is user installable. You can get one from many places online such as
Aug 20, 2012 | Lexmark T630 Laser Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Troubleshooting paper jam
You probably have a small piece of torn paper jammed right up against the paper jam sensor. You'll need to open it up and check the entire paper path for it. Even a small piece of paper can trip the sensor if it's in the right place. If you can't get at the entire paper path, you may need to take the printer to a qualified computer repair shop and have it done. Most shops won't charge you a lot for this job, and it can usually be done while you wait.
Dec 03, 2009 | Kyocera Mita FS 3750 Laser Printer
Paper Jam
You need to try clearing the paper using a airblower if you do not have a air blower try with a vacuum cleaner, surely it cleans up. Unless until you remove the paper it shows the msg.
If you think you have no other option and you tried everything its better to call some service guy and get it done.
Oct 03, 2009 | Office Equipment & Supplies
Paper jam
I would make sure you opened and closed EVERY section of the machine that was indicated on the op panel.... even if you found the paper already..
Apr 11, 2009 | Office Equipment & Supplies
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
Jul 27, 2008 | HP Color LaserJet 2600n Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
14 people viewed this question
Ben Johnson
