Question about Refrigerators
Center stip is extremely hot
The center strip where the doors meet is extremely hot and now the freezer is not working properly
  • 410 Answers
2 things you neeed to check first of all clean teh coils underneath the refrig. then pull unit from wall and pull off rear compartment cover and see if the fan that cools compressor is running. it is possible the motor is jammed or bad. if the motor is bad you can put a house fan blowing into the comp compartment until you get it repaired.
Posted on Jan 30, 2009
I have an LG American fridge freezer GRB207TUJA which the edge where the doors close on is very very hot
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | LG Refrigerators
Seals on my beco are hot to touch fridge freezer feel warm
Almost the same post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
Hi is it normal that the middle Paleo that the doors close onto seems really hot? We have an American style fridge freezer, everything else seems ok, but I have never noticed it before!! Thank you
Again a similar post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Where the two doors meet it is hot why?
Pull the refrig out and remove the rear panel . Check the fan there to see if it is working and the blade is not obstructed . If not working , and the blade is not obstructed , replace the fan motor . Also make sure the coils in front behind the kick plate are clean of dust , lint , etc . The cooling fan not working will cause the center door strip to get very hot .
Jun 13, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Center support of Side By Side is Hot to the touch
Hi, welcome to Fixya. The heat between the doors is normal and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. Just be sure the condensor fan isn't jammed and still turning. If not turning it can cause the unit to become extremely hot. The amount of heat can and is determined by several factor's such as, temperature setting - lower/colder the temperature is set the more the run time the hotter the strip. The ambient temperature - hotter the environment the more the unit runs the hotter the strip. The amount of "fresh" content added to the unit - new items add a lot of warmth thus demanding the unit to run more to remove this heat causing the strip to be hotter. Build up of dust & dirt on the condensor coils ( they should be vacuumed annually ) - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. Macmarkus :)
Jun 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
Center front partition is very hot!
Either your coils are dirty ( clean from the front after removing the kickplate , only what you can get to ) or , the condensor fan motor is bad ( motor which cools the compressor ) .
Jul 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Kennmore Cold spot Model # 57285791. The center strip where the two doors meet is extremely hot and everything in the freezer is defrosted.
Jan 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge side by side freezer refrigerator
That is called a heat strip. Used to keep moisture down around the door gaskets. You will need to roll unit out, take lower back plate off and check to see that the condinser fan is turning when compressor is on. If not,replace fan motor
Jul 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
455 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
