Truck doesn't stop at low speeds pedal won't go down and vibrates
SOURCE: Ford F-250 1999 Diesel Crew Cab Brake failure w/ABS light on
go to ford dealership and have them scan your truck with a scan tool
SOURCE: abs kicks in at low speed and pedal pressure
You have a weak or bad ABS sensor on one of the hubs. They are built into the hub and are not individually replaceable. Also rust buildup around the sensor will cause this same problem. To stop the ABS from kicking in untill repair just pull the fuse.
SOURCE: brakes grindind at low speed
Sounds like your getting abs activation when its not needed. Most likley one of the wheel speed sensors has failed. You do need to have a scan tool to read the live data from the abs module as the problem is occurring to pinpoint which sensor is faulty. The abs light will not come on because the abs module thinks its just working normally. I'm an ASE certified mechanic and have seen this problem many times on various vehicles. You might have to pay somebody to diagnose it, but replacing the sensor it a very easy task. I hope this helps.
SOURCE: abs skipping
If you can test the car without the ABS module to ensure that the ABS is not the cause of the problem, If you have a spare module you can have it replaced for a while to test if the module is faulty,
SOURCE: Ireplaced both wheel speed sensors due to abs
I had a 2001 silverado 2500 h.d. with the same problems. I took it to a gear head and he found that the emergency brake cable was loose causing it to trigger the warning light on the dash. As far as the low fuel guage I took it back to the gear head and he found that the float in the gas tank was broken causing the low fuel light to come on. The float wasnt a big deal until I lost track of mileage and ran the tank dry.
