Question about Motorola Mobility RAZR V3
V3 dead but keypad flashing
Hi, Went to charge my V3. Plugged the adaptor into the phone. The screen indicated that it was charging for about 3 seconds and then the phone went dead. Now, phone is completely dead and the keypad is flashing. Unable to turn on the phone, unable to charge it. No water damage and was not dropped. Tried removing the battery and the SIM card...nothing :( Any suggestions?! THANKS!
  • fatpunk1980 Jan 30, 2008
    keypad lights come on, but the phone is otherwise not functional and gets really hot.
    New Friend:
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Posted on Feb 26, 2009
Try a new battery.
Posted on Jul 29, 2007
Why doesn't it charge?
Hi Stacey, The links below are youtube videos showing how to fix white screen, CHEERS
Fix for Android Tablet White Screen Issue
white screen on cell phone YouTube
Apr 07, 2016 | Alcatel Cell Phones
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
I have a problem with asus eee 901. I've just bought it. It had linux, but it was changed into windows xp. Since it had been fully charged only once I was using it on battery and setting it up with new...
Remove the battery for a couple of minutes while the unit is not plugged into the a/c adaptor. Reinstall the battery, plug the unit into the a/c adaptor, and see if it will boot up.
Mar 14, 2009 | ASUS Eee PC 901 20G Notebook
V3 not charging
it's a hardware failure,, cant fix it here ..
Apr 15, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
Not charging
you need to try a new battery...if that does not work you have to get the phone reflash with the correct firmware.
Dec 20, 2007 | Motorola Mobility RAZR V3
My screen will turn on, but will not proceed.
hi
it seems you have a prob in the keypad flex. have it replaced and your prob is solved.
Oct 12, 2007 | Motorola Mobility RAZR V3
Razr v3 dead battery
you have a dead battery, this happens often. all you can do is just buy one, ebay
Oct 07, 2007 | Motorola Mobility RAZR V3
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
706 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
