Question about Reddy Heater-30-55,000 BTU Variable
Smell propane When I first used it I didn't smell anything it seemed to burn off all the fuel being supplied, but now it seems I smell the fumes of the propane as if it isn't buning it off. I tried to back off the pressure on the tank. That didn't help I made sure all my connections were tight still smells as if I have exess propane blowing in the garage. It gets to the point of smelling real bad. I do vent the garage when I use it. I have a two car garage I open one door about 12 inches.
  • 12 Answers
SOURCE: heater smells
I think that it is a cheap heater and the smell is the metal paint is burning .away I think that you should give it a little more time bec after that paint goes away it wont smell any more.
Posted on Dec 30, 2007
  • 3 Answers
SOURCE: i have just purchase a
Try running it outside where the oxygen level is 21%. Carbon Monoxide will kill you The smell might be the product if incomplete combustion CARBON MONOXIDE, or the fuel line pressure needs to be adjusted.
If you still get the smell the unit may defective. If you want to try adjusting the fuel line pressure, you will need a low pressure gauge 0-15 psi.remove a plug from the heater and set the pressure at the documented pressure, the other plug with the hole in it is the adjustment.
Posted on Jan 25, 2009
  • 5 Answers
SOURCE: smells like it is running rich
Whatever it is sounds like you should clean it... carbon and soot build up in exhaust... if it is a ventless (which is info you should have asked about) than you will find that it is the second heater in line and is starved for fuel.
Posted on Dec 10, 2009
heatman101
  • 43501 Answers
SOURCE: i have a ready heater
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Dec 14, 2010
SOURCE: I just bought a 30K
You need to ventilate this area while the units running! This is potentially a lethal situation!
You are competing with a flame for oxygen and breathing the carbon monoxide gasses
from the heater! Both unacceptable scenarios! you can easily die in this environment!
I cannot stress this enough! You need to open a window or crack the door enough to allow air to circulte and gasses to vent out and escape, If the burning of eyes is really bad your unit may not have sufficient combustion air, I can t tell you without seeing it precisely, you better vent that room though!
Posted on Dec 24, 2010
When I start my car, there is a very strong smell of exhaust fumes or maybe even gasoline in the car. It seems to lessen over time or maybe my sense of smell just adjusts to the smell. Any help with what...
the vehicle may need a service to ensure all fuel is being burned on ignition.
the exhaust may be broken under the car and exhaust fumes are being released.
I hope this was useful.
Jan 11, 2011 | 2003 Kia Spectra
Terrible smell and burns my eyes from 5gallon tank. First 5gallon tank was find as is small Coleman bottle . Can propane be bad from Supplier. It gives off sour smell and irritates eyes when burning?
I would not use it any further, I cant say if anything is in the gas, I doubt it, However the propane at too low a pressure etc, can cause this, dont use it with eyes butrning ever!
May 28, 2010 | All-Pro Propane Garage Shop Heaters - All...
Gas Smell
check under hood while it is running to see if there is gasoline dripping anywhere. You need to find it before it catches on fire. Use a bright flashlight and look at the fuel injectors and loser intake manifold as injector o-ring could be leaking. DO NOT use a lighter. Sorry, but I had to stress this. Gasoline does not burn. The fumes burn.
Jan 16, 2010 | 2005 Dodge Grand Caravan
Raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
Burning plastic smell westinghouse hdtv
The problem may cause by the defective transformer on Power supply board. there are 3 transformers on the power supply. http://www.lcdparts.net/LIPSInverterDetail.aspx?InverterOriginal=4H.B0700.051
Please do the vision inspection on power supply, you should be able see the obvious burn on one of these three big transformers.
May 11, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have just purchase a kerosene fan force (reddy) space heater ,we use it in a very drafty garage,but the strong smell of kerosene fumes are more then we can stand.we have tried scent additives but nothing...
Dec 05, 2008 | Reddy Heater RLP100 Portable Forced Air...
Smell of gas fumes underneath vehicle near fuel tank
this sounds like a gas pressure regulatur. a few minutes after starting,you start smelling fumes,and are getting bad gas mileage right?
Nov 16, 2008 | 2004 Volvo XC90
I also have a 2004 XC90 and a couple of months ago I had the exact same probelm... after multiple visits to my dealer's auto shop they figured out that it was the fuel pump. They replaced the fule pump and the smell disappeared. Good luck!
Oct 14, 2008 | 2005 Volvo XC90
Reddy Heater-30-55,000 BTU Variable Logo
51 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
