Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
TV TUner external not starting up
I have a Supercomp TV Tuner card, external.
I have connected it to my gfx card as well as monitor.
Tv cable is properly inserted.
Dont know why it doesnt display TV.
Do i need to make anychanges in settings to start TV.
    Problem Solver:
Safe mode
Power saving off
restart normally
Posted on Feb 01, 2009
External tv tuner supercomp problem in blue screen with picture
It is a serious problem and more complicated so you need to take it to the expert.
Aug 22, 2013 | Philips Brilliance 109S Monitor
Watch cable TV in Ubuntu
ubuntu is open source so you will have to check Conical for a driver that another user developed to support your card
Jun 12, 2013 | Ubuntu Linux 12.04 Precise Pangolin 32 Bit...
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
I want odyssey 501tv tuner internal driver software
i suggest u try the external TV tuner box...as those do not require any driver...not any installation of software...also it does not require ur computer to work...just ur monitor to be ON...
just connect ur monitor and computer thur the external TV tuner box and connect the TV cable to the tuner box...
Dec 23, 2009 | Computers & Internet
How can I watch Television on my laptop?
you may need an external TV tuner connected to your laptop, the cable signal/connection will be connected on the tv tuner.
Let me know for any clarifications
Sep 05, 2009 | Acer ASPIRE 5720-4649 Notebook
Vga Port
hey there!
by default, you cannot connect a tv signal cable like that..mainly because, the monitor does not have a built in tuner :)
what you need to do is get yourself a tv tuner card, internal or external and you're good to go :) you would need your entire PC though..some external tuners allow you to connect without the PC itself :)
Jun 03, 2008 | SAMTRON 55V 15" CRT Monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
312 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
