Question about Hitachi Televison & Video
4 yr. old Hitachi Ultravision Digital no picture
We get sound, can change channels, just no picture. Was working fine the night before.....
Possibly no high voltage to the tube (when on, won't raise hair on my arm....)
Is it dead?
  • 28 Answers
Hitachi did have some problems with cold solder joints on Horz. drive transformer. Although the connections looked o.k. you had to evacuate old solder and resolder. Could ne horzontal sweep transistor as well. (Hitachi uses to use one x-istor for HV drive and one for sweep).
Posted on Feb 08, 2009
  • 133 Answers
One of two things may be happening. 1) a loose connection (cold solder joint) has developed on the board that supplies the horizontal section or loose contacts around the flyback transformer . 2) A short in the line that feeds the horizontal . Without the horizontal section running you will have no High Voltage to light the pix tube or as you said won't raise the hair on your arm . If you take it to a shop tell them your problem. Your estimate would be based on the size of your TV and the parts and labor needed . Asked what there estimate fee is to look at the set if you take it to them . Or if you have soldering iron and some skills take it apart and give it a good look over . Make sure it is unplugged and be cafeful of the red wire that connects to the picture tube. Good luck
Posted on Feb 06, 2009
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
Sound, no picture, no display, just a black screen
its a Hitachi DLP
it has a lamp that illuminates the screen
it has most likely failed in your owners manuel it should be more specific and you can order a lamp and replace it your self
and you can order a lamp off of line or call hitachi
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
All of a sudden sound
The Time Warner support walked me through getting my SAP turned off on the CABLE BOX.
Nov 06, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Hitachi ultravision 50v500
there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
171 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
