Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Its for the same prblm ive mentioned previously.
After crash,The ram which is installed now is DDR1 400Mhz which is the only stick now.But my compt env now shows me some similar signs which happened with two sticks like-Pc turning a non responding machine fr some secs,i hv to wait for some time, While booting it takes time for switching from intel screen then some more time to swich to boot screen then to desktop.Also can i directly increase my video onboard ram from 64MB to 128MB from bios or needs some research??
  • 1,800 Answers
U need to see the specifications and ram frquency range of ur mothrboard so u can install the proper ddr.
take it apart and locate the model number of ur borad then past it in google and read a review.
for the Video onboard RAM
that works if u ve a buit in graphic card or a PCI graphic card.
plz rate this post.
Posted on Jan 30, 2009
Driver memory stick
Try putting the ram in another computer and see if you have the same problem. If the issue goes away one of the sticks of ram might not have been fully seated. If you get the same result you have a bad stick of ram. Go to the manufactures website and download ram checker and install it (free software). This will help diagnose your problem. If you get an error code write it down so you can give it to the manufacturer which indicates which error problem you have... If it turns out that you have a bad stick of ram contact the manufacturer and they may send you another stick of ram. Some manufacturers have a lifetime warranty on their ram. Hope this helps.
May 11, 2017 | Kingston 4GB Secure Digital High Capacity...
I have a Soyo P4VGA MB. When I purchased the board I made a huge mistake a nd installed only 256mg of DDR. Since then, I tryed to install a second stick of 256 DDR (same brand and specs) but the computer...
Take both ram sticks out and turn the PC on. If it makes no sound at all with the stick out this means you have a problem with the mother board. If it screams like a banshie the board should be okay. Try putting the new stick in the slot where the old one is and the old one in the other slot. It might read it that way, no guaranties this will work but it won't hurt. It is also possible you got a bad stick. It does happen.
Hope this helped.
Good Luck
cookEmonster
Oct 13, 2010 | Computers & Internet
My T6212 crashed. I replaced the hard drive with a new one but the installation process for Windows XP (and Ubuntu) starts but then hangs. Any ideas what could be causing this? Thank you for your help...
If you have multiple memory sticks(RAM), try using only 1 memory stick(at least 246MB of RAM) for the installation. It could be the memory causing the problem.
Hope this helps! :D
Sep 08, 2010 | E-Machines T6212 PC Desktop
My system is restarting after installing another 2GB dynite company RAM in another slot, with single 2GB ram it is working fine and my os is XPsp3.
just remove that ram and see the ram is that DDR or DDR1 or DDR2 if you want install the ram same as previous one and see these information i mention above
Aug 30, 2010 | Intel DG31PR Motherboard
1gb pc2700 333mhz ddr wont work
You may have just bought a stick of gum! This ram could have been sold on e-bay for any number of reasons. It's not likely that you can get your money back. Sometimes even identical appearing ram won't function with original ram. Check with tigerdirect.com on the web for ram and other computer parts. Good luck!
Feb 16, 2010 | HP Compaq d530 SFF PC Desktop
Computer crashes with my RAM sticks both in
First thing i would suspect is a bad ram stick. Here is a link to a free tool you can use to test the ram if you dont have an application for that:
http://ubcdfull.sourceforge.net/
use the "memtest" programs on there.
I know, it works fine with 1 stick, but its a dual channel board so the ram may only fail on 2 sticks, so check it out.
If RAM tests fine, then go for a BIOS update. I have run into some weird things with that chipset in ragards to raid vs mem. Using RAID on that system?
Is your system overclocked? try running it at standard speed. If that fixes it then run at a lower overclock or get better cooling.
If it still doesnt work after all that, see if you cant borrow another processor from someone and try running it with a different processor.
If that is not the problem, try running a fresh load of windows for a couple of days, with nothing but windows loaded. If that fixes it then your problem is software, and will go away with the reload.
If you are STILL having trouble after all that, then its time to try swapping out the motherboard. Hopefully yours is still under warranty. If not, I like Asus boards - as they have a 3 year warranty and are just good boards.
Dec 04, 2009 | Gigabyte GA-EP35-DS3L Intel P35 Core 2 Duo...
PNY PC2-5300 RAM sticks are making my Compaq Presario C751NR crash. Any suggestions?
Do you have two different brands of sticks installed? If so, this could cause the crashing if not it may be too much for the computer to handle.
Nov 27, 2009 | Compaq Presario Notebook
Getting 3 beeps when starting the comp. with no screen.
some prblm is dere wid d ddr1 or ddr2 compatibility...jst check d compatibility of d ram n insert accordingly..having fit at both ends...that's it...it's not a big issue...
Apr 11, 2009 | Toshiba Satellite X205-SLI1 Notebook
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Problems with Ram
Hi, with my own Foxconn board I had simalar problems, the Foxconn website gave me the needed steps to rest the bios to cope with 4g RAM. I have forgotten the steps now. The web page is the one on the install disk, if you go to Foxconn via google you will only get a company promo. Regards mistyman
Sep 10, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
