Question about Canon PIXMA MP600 all-In-One InkJet Printer
I can't get the scan to scan dark enough to read.
My son showed me once. It had to do with the settings button, but I don't remember how to do it.
    President:
  • 2,692 Answers
Still now it doesnt work print out more or less white dark
I jut solved the problem on a same code error, I have a Cannon MG2120. I simply held the "reset" button and the machine reset. You may have had an initial printer test on set up. The ink shouldn't matter as its a combo scanner/printer/copy. You should be able to use the scanner. Remember to hit the "scan" button only or you may queue a new printing project.
So, solution is:
1. Press and Hold: "Stop/Reset" Button
2. Press once: "SCAN" button
Jan 31, 2014 | Kyocera Mita KM-P4845W Network Junction...
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
Lexmark x6180 Printer. Unable able to Scan. I turned on my printed and selected "Scan" button, located with two other buttons ("Copy" and "Fax" under the section titled...
On the printer operator panel, press Black to begin a black and white scan or Color to begin a color scan. You can rename the file only on your computer once the scanned file is displayed.
Jun 19, 2011 | Lexmark X6180 Printer
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
We have a Technika combo 22" tv, my son was playing about with the remote, resulting in us having no picture. It looks as though he has been pressing the contrast/brightness buttons. we have sound and when...
hi did you get any solutions to this? I have the exact same problem....also before your son gets into trouble for button bashing i dont think it has anything to do with that, as my tv just did it whilst i was in the middle of watching something :) please let me know x
Jan 11, 2010 | Televison & Video
No light behind the heating and air conditioning controls
is it a manual or auto climate system ?? I don"t remember the auto deal but..... if manual- set the fan speed to #2 position and pull the knob straight off. It might put up a fight and you might have to use both hands... no joke. When the knob is off you'll see the little bugger, it might have simply fell outta the socket
Dec 14, 2009 | 2001 Volkswagen Passat
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
How can I change the Resolution?
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Sep 06, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Canon PIXMA MP600 all-In-One InkJet Printer Logo
112 people viewed this question
old marine
old marine
