Question about Refrigerators
Refrigerator Door not closing properly
Whirlpool refrigerator with top freezer. There is a gap of about 1/2 inch at the top corner of refrigerator door. It seem like the door is out of line. Is it possible to adjust the door?
  • terryandmoni Jan 30, 2009
    I leveled the refrigerator, but it did not completely correct the problem. The feet were missing, so I used some shims. It is level accross the front and tilted to the rear. The model number is: ET18JKXMNRO. It is an older model owned by a widow I am trying to help out. I noticed the problem after I replaced the seal. I do not know if the problem was there with the old seal because I only noticed it afterwards. Anymore suggestions?
  • terryandmoni Feb 01, 2009
    I'll have to wait until Monday to try this out. Thanks for your help and speedy responses.
Doors hang unevenly
Posted on Aug 31, 2009
  • 257 Answers
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
  • Jim London
    Jim London Jan 30, 2009
    Thanks for trying? Hope you don't need anymore advice!
  • Jim London
    Jim London Jan 31, 2009
    Yo Again!, I like you, try to help others and the details about the feet and the seal are important when troubleshooting long distance. I now believe more than ever that the box itself is out of kilter. It could be partially the seal but we can check that.
    Open the doors and put the level on each to be sure they are the same. If you have ever built anything square or replaced a screen then you will know what I am talking about only this is in three dimensions, which is a lot of back and forth. If there is any difference at all you have to work on the leveling. If you have a carpenters square, check the inside of all four corners there should be NO space, if it is square. Now the seal part, if you remember the old one, did you replace it because it was brittle or deformed? If the box got out of square as the old plastic on the feet disintegrated the seal would slowly deform otherwise would probably outlast the sheet metal. I try my best to answer but most folks leave out details that help the long distance troubleshooting and remember we are giving up our free time to help you. Good Luck!
596.77277790 freezer ice buildup in front top corner
If your refrigerator is fairly new, the seals probably are OK. More likely, the door alignment has to be adjusted.
Jan 01, 2014 | Kenmore 22.4 cu. ft. Bottom Freezer...
Gap in large freezer door seal
if you cant adjust the door, ger some weather striping, some that is some what thin. so it can mold to exsisting area
Aug 04, 2012 | Gladiator Freezerator Top Freezer...
I cannot get the freezer door to close all the way. The left side will close and fit snuggly but the right side is still ajar about 1/4 of an inch. I have removed anything that I thought might be...
There are ways to adjust the door. It depends on your skill level. How many baskets are on rollers? Check the alignment of the top basket if you have one, it could be interfering with the closure. Put a video camera in the drawer with the lights on when you close it and look for blockage.
Jan 26, 2011 | Whirlpool GB2SHDXP Bottom Freezer...
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
My refrigerator Door (Whirlpool Gold)does not close like it shoul
You need to bend the door, if the gap is at the top put your foot between the frig door and the bottom and push the door closed slightly. so you can check it and do a small amount at a time. till tou reach the point that the door closes tight. if the gap is at the bottom put a shoe or something about 4 to 5 inches wide. go for it you can fix this..... saw
Dec 05, 2009 | Washing Machines
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Bottom freezer door moves top to bottom by moving handle in & out
Hi, most models have adjustment screws near the track connected to the door if this is a slide out door. If this is a swing out door, you might be able to twist the door back in shape.
If the gap is only in the corner of the door, try inserting a piece of paper towl rolled/folded up behind the gasket to help stretch it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | LG LRBC22544 Stainless Steel Bottom...
Exterior Moisture
sounds like you have warm air getting into the machine, id check to make sure the doors are closing tightly around all sides with no gaps
Oct 26, 2008 | Whirlpool Refrigerators
Light switch
correct, you can either take off the refrig door and place asmall shim under the hinge raising it an 1/8 inch or soor you can slightly pry down the light switch from the liner, and fill the small gap created with a small bead of silicone
Oct 23, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
1,252 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
