I'm trying to locate a Consumer/Prosumer camcorder that we can hook up to a PC for live video feeds as a webcam.
We currently use the Cannon GL1 to connect by Firewire to laptop in an Adobe Connect meeting, using the image as a webcam in Adobe Connect.
We want to get away from Firewire because the classroom computers don't have this option and limits the room availability to host distant classroom seminars.
The 2 camcorders we are testing now doesn't apprea to have the option of live webcam feeds. We are working with the Sony DCR-DVD508 and Canon HV30. Both appear to have Firewire options but no USB.
If you can make a suggestion on a model or provide details on what I can do to make the 2 testing cams work with USB, I would be most appreciative.
One more thing. To throw some more curves, the access to the classroom computers to download software and/or drivers make it more of a problem. Please help with what details you can provide.
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Canon VIXIA HV30 DV Camcorder
My Vixia HV30 shows it's recording and marking timecode, but it will not playback video. I checked...
(More)
My Vixia HV30 shows it's recording and marking timecode, but it will not playback video. I checked all the settings to match another vixia that IS recordeing. Any suggestions?
hey, it appears to record fine, but when I go to watch the footage or else stream it onto my...
(More)
hey, it appears to record fine, but when I go to watch the footage or else stream it onto my computer, it sometimes gets very jerky and blue flashes happen. I have it plugged in when i'm doing this so i know it's not just the battery. it doesn't do it all the time either, it'll just randomly happen
I can't connect my new refurbished canon vixia HV 30 camera because the 1394 port is not working, I...
(More)
I can't connect my new refurbished canon vixia HV 30 camera because the 1394 port is not working, I connected before to PC with no problem
i was shooting still pics with my vixia .. but i was doing continuous shooting .. with flashing .....
(More)
i was shooting still pics with my vixia .. but i was doing continuous shooting .. with flashing .. and the screen turned black .. and it jammed .. if i switched the mode to play or to off .. it will stay as it is .. few seconds and then it turned off ( i switched it off ) i putted on charger .. it worked again .. but i noticed .. that there was a sound .. when i move the cam upward or downward .. as if the lens is moving inside .. when i am on the camera mode it's not there .. and i tested the zoom it's working .. but when it's off or on play .. it makes the same sound .. and i can feel something is bouncing inside ! .. why this happened ? and what's it about .. and how can i make it normal again ? thanks
MY HV30 made a funny noise and stopped recording. When I opened the cassette the tape was crinkled...
(More)
MY HV30 made a funny noise and stopped recording. When I opened the cassette the tape was crinkled and pulled out a little. I tried to reload a tape but the camera side will not shut. Because it will not shut the tape does not lower it's self into position. Any ideas?
