Question about Acer Aspire 4520-5582 Notebook
My laptop wont start
I did a windows update and now it says computer cant start. The screen says Start Up Repair scan. It has been scanning all night.
Had to take it to a computer repair shop
Posted on Feb 02, 2009
The emachines e627 laptop fails to boot up! Cannot figure out why it wont boot up to the main login screen.
1st have you tried the repair on the screen at the start of the video?
if so u will probable have to format and reinstall windows...
2nd if u have another computer that works you can take the hard drive out and put it in other computer and save pix and personal stuff off.....but try running scan disk on drive then the repair.
how to run SCAN DISK
eMachines Laptop Repair Fix Dis-assembly Tutorial
Mar 17, 2013 | Computers & Internet
Cant start up goes to a startup repair then restarts
Turn off your computer. Than go ahead and turn it back on while hitting the key "F8". Continue to do so until you see a screen appear with options like "Safe Mode". Use the arrow keys and press down until you have highlighted "Safe Mode with networking". Press enter and let the computer do its thing. Once down, login to the computer. If you are able to see the desktop again, go ahead and open your browser and download the following:
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE Update the software and run a full scan. Once done, click remove and than finish. It will prompt you to reboot. Only do so if the other scan is finished
http://www.eset.com/us/online-scanner/run Agree to the use of the scanner, let it update, and finally hit scan.
After both scans, your computer should be clean and you will be able to boot into your computer normally
If the above does not work, try the first step of hitting "F8" and select the windows repair. Please contact me with any questions
May 03, 2011 | Acer Aspire 5542 Notebook
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
Windows wont boot
reinstall your os again not update, may be you will not facing the problem again.
Mar 31, 2010 | Acer Aspire 5315 Notebook
WINDOWS WONT START UP when i try to repair it it says it is dowhloading windows and then a minute or two later it says it could not start and to turn off the laptop
  1. Hi, try rebooting the computer in one of the different "Modes" at startup, when the window prompts, "press the F2 button, select either "recovery mode" or "Safe" mode, if the computer, recycle back to the "Option start modes,; choose "Normal Mode." Next go to the Computer, open, and select "Properties," click to "Tools," in the (Error checking) window, select the (Check Now), you may have to choose "when the computer startup option." click "Apply and OK." When you start the computer again, a "Full" Disk Scan, will begin; be patience! this can take awhile. After the scan is complete, you should have an idea of what the problem is exactly. If you need further assistance afterwards? I'll be looking for an updated "Post" Thanks"Did this solution help?"
Jan 17, 2010 | Toshiba Computers & Internet
My computer has a virus and now it won't let me download any security software. what do i do?
If your PC wont let you download any security software then you should go to a public library and download your software, save it to a disk and go home and install it....run the software and check for updates if you cant update, run the software without updating after the scan attempt another update, I recomend AVAST ANTIVIRUS HOME its free for a year with registration and works great
Sep 27, 2009 | Dell Inspiron 6000 Notebook
Start up fails and keeps going to scan disc
Yes, that is the same as reformatting, as when you load XP, that is what it does. It sounds like you have a bad hard drive, and you should replace it.
Mar 17, 2009 | Acer Aspire 5630 Notebook
Blue screen
off the windows ubdate
Feb 19, 2009 | Dell Studio 17 Laptop
Acer aspire 5630 wont start up. please help!!!
Press F8 key and go into safe mode when u start the computer,tap it a few times until you get the safe mode screen,try choosing "Last known good configuration" and start. If this doesnt work, you can try system restore.
Dec 16, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 4520-5582 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
