Question about Maytag Atlantis MDE6400AY Electric Dryer
Dryer won't start
We had a power outage while my dryer was on. Now the dryer does not turn on (Maytag electric dryer MDET336AYW).
    Sniper:
  • 50 Answers
Check your circuit breakers for dryer they may have tripped whenlights went out. write back if not the problem let us know a little more about problem
Posted on Feb 06, 2009
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
MY MAYTAG MDE9700AYW WILL NOT TURN ON
Are you getting power at the console? Also, check to see if one of the breakers has not tripped. Dryer runs on 220v and you may have tripped one breaker that will show power to the unit but won't let it start.
Dec 24, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
We had a power outage and now the dryer doesn't work even when there is power going to it. Is there a relay switch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start - is plugged in and all home fuses are working. Could be an interal fuse that was fried during a power outage. How can I check that?
heatman101
Aug 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Power outage recently. won't turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 10, 2010 | Kenmore 64672 Electric Dryer
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
We had a power outage the other day, and now our Maytag MDE308DAYW dryer just buzzes when we try to start it. At first, I unplugged the power, let it sit a few minutes, and plugged the power back in, and...
Hi fixya. I solved the problem myself, it was pretty easy. I just unplugged the power; let it sit for a minute; plugged the power back in; then I opened the dryer door and while manually holding down the door switch, I manually spun the dryer drum and simultaneously my son hit the start switch - you need three hands to perform this procedure - and it started running! Then I let it run for at least an hour, and ever since that it has started perfectly well.
Oct 02, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer,timer switch won'tmove & cool air only.
Begin by replacing the times. Then you will most likely find that you are back in business.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
My maytag dryer MDET336AYW won't come on
probably have a back door switch. look and see if when you close the door it closes the switch
Jan 04, 2009 | Dryers
Maytag Atlantis MDE6400AY Electric Dryer Logo
165 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
