Question about Lexmark X502N All-In-One Laser Printer
WARINING CPU FAN locked on Lexmark X502N
Printer is failing to print with the above error message
  • scot_glassfo May 02, 2009
    Lexmark x502n is displaying message - Warning : CPU fan is locked ! Is this an informational message that needs my attention, or an easy fix ? I just got the printer and don't want to tear it apart if I don't have to. I mostly work on Optra S & T models. Any advise would be greatly appreciated !!
    Thanks !
    Scot Glassford
    scot_glassford@hotmail.com
  • 53 Answers
Sounds like this will need to be looked at by a qualified service technician. You may want to contact Lexmark Customer Support. If your printer is still under warranty it should probably be covered.
Posted on May 27, 2009
  • dshuval May 11, 2011
    Lexmark Part # 40X0410 Is the part you need.
Einfach mal bei uns melden => Wir haben den Lüfter lagernd.
24 Volt. 50 x 50mm mit OEM-Molex Stecker.
Das ganze mit Rechnung.
Kosten: 29,99 Euro => ohne irgendwo rumlöten zu müßen.
Seitendeckel aufschrauben = Lüfter entfernen und neuen einsetzen.
Dauer: 2-3 min
Werkzeug: Kreuzschraubendreher für 2 Schrauben
Kontakt: info@webspace-for-you.de
Web: http://webspace-for-you.de
Posted on Jul 23, 2010
  • BirdyFitz May 10, 2011
    Hab den Lüfter bekommen. Leider kein original Ersatzteil. Sieht ziemlich gebastelt aus.
    Problem Solver:
  • 7 Answers
Wow, after hours of searching I found the right connectors for the fan since it comes with bare wires when ordered from www.cypower.com. (The fan to order is a 24v DC Y.S. Tech FD245010MB.)The connectors are from JST America and can be ordered from www.digikey.com.
Part 455-1126-ND (housing that takes pins spaced 2mm apart)
Part 455-2148-1-ND (pins)
You have to order at least 10 housings and 100 pins but all of that costs about $2.50.
You can also order the crimp tool but that costs $1,300. I'll just use a needle nose pliers.
Posted on Mar 20, 2010
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
Is my new Epson printer compatible with Linux
http://www.openprinting.org/printers
http://www.openprinting.org/printers/manufacturer/Epson
Don't really know you failed to provide the exact model number ????????????????????????????????????????????
see if model number is listed in the above link
Jan 09, 2017 | Epson Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
LSU error SAMSUNG SCX 4725FN
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for a service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 27, 2011 | Samsung SCX-4725 Laser Printer
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Lexmark X502N All-In-One Laser Printer Logo
2,717 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
