Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
Ps2 controller is the accumulated dust yellow?do i remove all of it from the board or just from the top right corner? its is quite hard to get off. i tried using toothpick sticks. shall i soak a cloth with water and clean in, will it worsern the problem. Thanks a lot for helping me.
  • johnny_94 Jan 31, 2009
    do i remove the yellow stuff around the soldering.is that effecting the controller?. or just the black dust on the green board. i removed the dust around the soldering but it still had the same problem. The dust around the soldering was yellow and quite hard to get off. i scraped most of it off with a screw driver but it still doesn't work.was that the right board? so it just on the green board that i have to remove the dust?or the the metal bits as well?
  • 67 Answers
Color is black sticking on the board where the rubber buttons touches use only damp cloth(just little amount of water)make sure its dry before you close the controller.
Posted on Jan 31, 2009
Keyboard not working
check the keyboard ps2 lead is has a dust free secure seating
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jun 20, 2012 | Dell 07N242 PS2 SK-8110 Keyboard
Mother no conect usb and ps2
this could be a driver issue with the usb the ps2 could be the same but if its a ps2 keyboard or mouse might be leads
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
May 01, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Ps2 controller
Yap!accumulated dust sticking on the board were the buttons touches. You must removed all of those.use cotton balls with alcohol or use clean damp cloth.
Jan 28, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock2 controller not working
Yes! your right, it's inside of the controller .what you can do is open the controller clean the board by using cotton buds with alcohol or cleaner you will notice accumulated dust preventing the buttons from touching the board you need to remove those.
Jan 25, 2009 | Sony PlayStation 2 (PS2) Console
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
Jan 17, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 controller buttons not working
Jan 15, 2009 | Sony PS2 Dual Shock 2 Controller...
Won't read PS2 Games
If you have a slim ps2 then the laser probably needs replaced. It's not that hard to do and the parts are cheap.
Feb 21, 2008 | Sony PlayStation 2 (PS2) Console
Powering off
Hi 256male,
  1. You posted twice for the same problem. Cleanup the internal parts of your PS2.
  2. Remove the screw covers and 8 screws.
  3. Cut the warranty seal at the seams.
  4. Lift the top cover from the rear, and pull forward, then roll it to the left. Preserve the Reset Eject ribbon.
  5. Remove the two screws on both sides of the controller port.
  6. Remove the screws to the right and left of the Power socket.
  7. Lift the guts out from the back.
  8. You should be able to see how much dust and lint buildup you have .
  9. Clean everything using a dry paint brush.
  10. Reassemble
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 slimline
He's right, it is a line, but it's not a big problem. If you keep playing with that wire, eventually that yellow part in your PS will come loose. It took me about 10 min. to fix mine with the same problem, and all I needed was a small philips screwdriver and a soldering iron. I bought my soldering iron for about $16 at Lowe's and it comes with batteries and soldering. First, you need to open your PS: you flip it over, pop those little square plastic covers out (only 6 of them). I used my finger nail to pop them out; now, you'll notice that there's a total of 8 of those square-type things, don't worry about the ones in front corners (right underneath Controller Port 1 and Remote Controller Receiver). Once you do all these you'll find 6 screws, so use your screwdriver to get'em out. Flip your PS over again. Now you'll be able to pop the top cover out, just be careful, it's a little tricky but you'll make it. With the cover out of the way, you can see now the inside of your PS. Try to locate a screw between the two Controller Ports, it'll need to come out. Once you get that screw out of your way, remove the bottom cover carefully; make sure you remove that board thing where the Reset/Power button lays from the cover as well. Now you have a naked PS haha. Flip your PS over locate where the power cable is plugged in (it's like a yellow square-thing). Looking at it from the bottom, try to put some presure on it with your finger and try to move just a little bit and you'll notice that one of the solderings holding the yellow thing together to the green board is cracked loose (if not both). So now it's time to get that soldering iron to work. If I recall, it'll take about 30 to 45 sec. for soldering iron to get to it's working temperature. Once it's ready to work put presure again with your finger to that yellow part and try to solder bond that cracked soldering back together. I did it by heating the soldering touching the green board so it'd hold the yellow part in place. I'm sure you'll do good, just be pacient. Use your finger again to try moving it. Once it doesn't move anymore IT'S DONE. Just get those covers back together, first the bottom one, then the screw between the Controller Ports, and last the top cover with the 6 screws and covers. Hopefully this will work for you as it worked for me.
Jul 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
