Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Red CRT Socket....Part # ???
Anyone know the Phillips part # to the CRT socket for the red bulb?
    Scholar:
  • 87 Answers
The part # is 313503710081 this number is good for all 3 picture tubes.
Posted on Jan 30, 2009
Sonata tail light socket melted. attempting to replace with after market socket. red, green and black coming form vehicle.
If you have a test light or voltmeter, turn park lights on and find the one wire on vehicle that is hot-it will almost surely be red or green, as the black is surely the ground wire. Now on the new socket, you need to know this: If those bulbs are two filament bulbs (one filament for park lights, and the other filament for brake or turn or both) the brake light and the turn light will be brighter than the park lights. You can tell the difference in brightness, and the brake lights are always brighter than the tail (or park) lights.
How many bulbs are on this socket? Do you have 2-filamet bulbs or just one filament bulbs? Maybe you can figure it out by looking at the other side, see how or which lights are for tails and which for brakes.
Feb 15, 2018 | Cars & Trucks
Why primary light bulb has no power to bulb socket on a Zeiss S 3
Check that small rotary switch, below the pot for red, has been selected to allow footpedal switching of the light.
May 02, 2014 | Zeiss OPMI 6S on S3 Stand Microscope,...
I replaced the crt coolant in my 62 inch phillips rear projection tv and the green and red are perfect but the blue is still out of focus when I go to the convergence the cross is perfect but the blue is...
hi,
try to change the crt base socket of blue gun and then try. i will suggest if you replace the base socket change all the three at the same time.
crt base
ok
Jan 20, 2011 | Televison & Video
Red tube wont align,red ghost shadows on the picture
hi,
check the red guns crt base socket . may be it have some problem. when u change the crt base try to change all the three guns base socket.
ok
Jan 01, 2011 | Sony KP-53V80 53" Rear Projection...
Phillips 43PP92 0217 red blue converge
here is the sulution to ure coror problem take the back of the tv off turn on the tv and look directly into the bulbs blue red and green most likely you will see that the bulbs look cloudy the liquid in the bulbs after time begains to grow a fungus in them u need to get some crestail crear projector bulb fluid take the bulb assembly out of the the tv there r 3 of then take a socket wrench and un screw the bulbs take after draning the curent fluid out therr is a drain plug on the bottom then dissasimble the bulb and clean the projector magnifine lens with windex and a lint free paper towls clean the gasket as well onces you get the filmy fungus out of the bulb make sure u do not touch the inside and get it dirty again put the bulb back together then fill it up with the new fluid make sure to tap out the bubbles then put the plug back on it a reinstall the bulb ONLY DO ONE BULB AT A TIME SO U MIX THEM UP reinstall the wireing to the board then do the next one once ur done u will need to fight with the alinment ajustment inside the tv and also in the programing also might have to set ur colar to if ur scared to do this a tv repair man charges about 350 to 450 $$$ to do trust me u can do it your self just be carfull dont get water on the motherboard
Jan 02, 2009 | Philips 60P8341 60" Rear Projection...
No color red
you either have a bad red drive circuit or a bad red crt. try switching the crt socket from the green to the red crt and see if the red crt will light up. If it doesnt you will need a new CRT. If it still doesnt light up then you will need to troubleshoot the red drive circuitry. Let me know if you need more assistance.
Mar 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sound but no picture
I ran into this problem before and I can tell you what parts to check/replace - if you know how to do that. Since it took me hours of troubleshooting time, I would expect to be compensated a small cash fee for this info, but I don't know how this works on this site.
Jan 20, 2008 | Philips 32PT6441/37 32" TV
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
No red in picture
It could be a dry solder joint on the base socket pcb. Try resoldering the base socket, and try for dry joints on the main board also. Check if the rgb voltages are steady on the crt driver transistor bases.
Jan 10, 2008 | Televison & Video
Red bulb not working RCA P85927
Before we think of replacing the bulb, check the heater if it gets the power,check also for loose contact on the CRT socket.
Aug 09, 2007 | RCA P52926 52" Rear Projection Television
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
