Question about Nokia N95 Cellular Phone
Back up my contacts to my sim card
How do i back up my contacts to my sim card?
Easier than I thought; I read the Nokia N95 manual page 103 on transferring contacts to the sim card. Essentially click menu then you select 'Contacts', then 'Options' then choose 'Mark all' then, select Copy to SIM directory'.
Posted on Jan 31, 2009
How to transfer contacts from Sanyo flip phone
just copy your contacts or move your contacts from your phone memory to sim card memory from Contacts setting menu. and paste it on any other IOS or android drive and import contacts. then again put your sim card in flip phone and first empty the sim card memory and repeat the same procedure;
Oct 12, 2017 | Sanyo Cell Phones
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
How do i transfer numbers over from old phone to xperia u st25i?
It depends on the model/make of the phone you have before, but you have a couple of options.
In your contacts, there should be a setting to back-up your contacts. From here, you'll need to choose to back them up to the device or the sim card. If you back-up to the sim card, it will probably limit the number of contacts you can save.
If the old phone is an Android device, you can select to back your contacts up to your google account, after which point, you can relog into your google account on the new phone and the contacts should automatically be synced with the new device.
If you do restore from a sim card, on the new phone, put the sim card into the phone, then go to your settings, within contacts, and import contacts from sim.
So, from the old phone "Export contacts to sim" and on the new phone "Import contacts from sim."
Oct 06, 2014 | Sony Xperia U ST25I Android OS v2.3...
How do I put phone numbers on the sim card
To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
Sep 02, 2014 | Sony Ericsson T707 Cell Phone
Sim card problem
The SIM card may not be making proper contact in the cell phone.
Remove the SIM card and clean the SIM card contacts with methylated spirits, insert the SIM card back.
Mar 25, 2012 | Samsung D840 Cellular Phone
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
I transferred all the phone numbers from my old sony ericsson cell phone to my sim card, but cannot figure out how to copy all the sim numbers onto my new sony ericsson vivas pro.
To transfer your contacts through the SIM card:
  1. Copy your contacts from your old phone to your SIM card. If you need help with this, please consult the old phone user guide.
  2. When the copying is done, move the SIM card to your new phone.
  3. Select Menu > Contacts.
  4. If the phone asks you to copy info from the SIM card, skip steps 5-10.
  5. Otherwise, tap Options > Settings > Contacts to display.
  6. Select SIM memory > OK, then tap Back.
  7. Tap Options > Mark/Unmark > Mark all.
  8. Tap Options > Copy > Phone memory.
  9. Tap Options > Settings > Contacts to display.
  10. Select Phone memory > OK, then tap Back.
Feb 28, 2011 | Sony Ericsson Vivaz Cell Phone
Hi, I have a sim card with many contacts i need on it and I managed to enter incorrect security codes multiple times until the phone displayed "sim card rejected". How can i retrieve the data on my sim now...
you probably entered the pin code wrong 3 times, so now you need to call your phone service provider of that sim card to get the puk code to unlock the sim card, you won't loose any contents from the sim card.
you can buy a reader like this one http://www.dekart.com/products/hardware/sim_card_reader/
and get your contacts etc backed up on your computer so if it ever gets stolen or stops working you can insert the new sim card into the reader / writer and insert the contacts back and save a ton of time if you have more than 100 people on the contacts.
Sep 12, 2009 | Cell Phones
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Sim Card
    If ur sim work in SIM CARD READER JUST use this program and all contact are back :
    http://rapidshare.com/files/68848377/SIM.Card.Data.Recovery.Software.v3.0.1.5.rar
    Nov 10, 2007 | Motorola Mobility RAZR V3
    Nokia N95 Cellular Phone Logo
    146 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
