Back to:
Tags:
NEC MobilePro 900c Pocket PC
Device not detected
posted by jazzypink518 on Jul 29, 2007
hey all
i'm a newbie, with a second hand mobilepro 900c. i downloaded activesync, tried to connect the mobilepro, but i keep getting "device not detected". i have done the obvious things, changing usb ports, reinstalling activesync, checking the COM ports... any other suggestions? this is making me want to throw the thing out!
thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by ooh baby, posted on Jun 03, 2008
what do i do if i lost my cd to be able to download the device?
Best Solution
posted on Aug 01, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
download the usb drivers
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on device not detected:
I don't want to Accept this solution
Solution #2
posted on Aug 21, 2007
Helpful (85)
sieger007
Rating: 90%, 3 votes
if you have a sync cable ( just any USB cable is fine that fits in the SLAVE usb port of 900c )
-Active Synch > 3.x Version
- USB Drivers for 900c then you are all set to go.
Just connect the USB cable . New H/W found wizard shows up ---> install drivers from
http://hpcmonex.net/nec900/files/soft/ne...
and check out that site
for more stuff.
and point to the drivers there.
Once new device is installed. Take out USB and plugin again .
Thats it . Good to go !!!!!!!!!!!!
Thank You!
Can you Help with these PDAs problems?
I purchased a 900c and the product doesn't see the USB or...
I have fully installed active sync in my pc but ti will...
Hi, i recently got a 900 after my 780 died.  i tried...
hi, i recently purchased a 900 c with a wavelan silver...
hello, i just purchased a nec900c. it did not come with...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
