Question about Meade ETX-90EC (325 x 90mm) Telescope
Horizontal moter problem
I bought this second hand but it worked O.K.for quite a while. Now it doesn't move horizontally. The motor makes a noise but there is a loud buzzing as though some clutch is slipping. Vertical works O.K. Move smoothly if I slacken off the clutch lever so it's not obstructed. What do I do?
  • 36 Answers
This is probably not what you want to here but it most like needs to go back to Meade for repair. There website is here: http://www.meade.com/.
You may want to also check here for further support: http://www.weasner.com/etx/menu.html. Mike Weasner is quite knowledgeable about the ETX line.
Good Luck!
-jodair
Posted on Apr 06, 2009
How to clear E000051-0000 in IR3300 Photocopy Machine
E051-0000- At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main Cause- The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO:Connect the connectors.
2. Sensor lever (damage and interference),
Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES:
a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty.
Replace the motor.
NO: Replace the DC controller PCB.
Aug 17, 2016 | Canon IR 3300 Digital Copier
Bought new 7 gallon 1HP horizontal craftsman compressor. Used first day worked great . Second day plug it up hit on switch and all it does is click when you cut it on and make a humming sound
does it have oil? take it back for a replaement. pull the belt off and see if the motor is still good. turn the pump by hand to check for free turning.
Apr 22, 2015 | Craftsman Air Tools & Compressors
My IR 3300 display E000051-0000 please help me...
E051
0000 At start-up, home position is not detected when the horizontal registration
Main cause The horizontal home position sensor is faulty. The horizontal registration
Action
1. Connector
a. DC controller PCB (J304) relay connector horizontal registration
b. DC controller PCB (J304) relay connector horizontal registration
motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
YES: a. The horizontal registration assembly is out of place because of
sensor.
PCB?
YES: The horizontal registration motor is faulty. Replace the motor.
As You can see, is better to call service.
Hope that helps!
Aug 01, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
In 2004 I bought a monitor Hansol 930 D model, (model no.D19BL, s/n A23490411020263) Since 2011, horizontal image began to narrow, now horizontal image H-size is 210 mm. vertical image size is ...
The horizontal deflection coil is shorted. There is no way to fix that, the entire tube would have to be replaced and that would cost as much as a new monitor.
Just buy a second-hand LCD monitor from here
http://www.diabloscomputer.ro/monitoare-second-hand-fujitsu-siemens-p19-2
Asta l-am luat eu si are o imagine excelenta.
Jul 01, 2011 | Hansol Europe 930D 19" CRT Monitor
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
sensor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
LG wm1814cw motor tries to turn but only moves 1/2"
The motor or "stator" as the call it in your machine is bad and needs to be replaced.
Apr 08, 2008 | LG WM1814CW Front Load Washer
Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Mar 21, 2008 | Canon imageRUNNER 210S Copier
Meade ETX-90EC (325 x 90mm) Telescope Logo
305 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Eric Hidle
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
