Question about HP PSC 2110 All-In-One InkJet Printer
Hp 2110 All in One Printer
I tried one of the "refurbished" print cartridges (black). The printer never recognized it and always said "cartridge installed incorrectly." I got a new Hp cartridge, and put it in. I got the prompt to align the cartridges. It printed both sheets, and I put the one with the lines on the scanner glass. Now it says aligning. . . please wait. But it isn't doing anything. I have turned it off and on, unplugged it, taken the cartridges out and put them back in, opened all the doors, etc. nothing will make it align the cartridges. When I push setup it says Busy.
  • 1 more comment
  • Anonymous Mar 24, 2008
    changed the black ink cartridge and now it will not align the cartridges. screen just keeps saying aligning please wait.....but then nothing. it is also never scanning the alignment sheet.
  • hillskier Mar 28, 2008
    I removed an empty black refill cartridge and replaced it with a new HP 45 (black) cartridge. Now the printer, an HP 950 (all-in-one inkjet), says an incorrect printer cartridge has been installed. I have reinserted the cartridge several times, turned off the printer, turned off the 'puter and printer, pushed the blinking buttons on the printer and gone thru set-up twice without success. Has the printer changed allegiances? or could something on the printer been sabotaged by the old refill cartridge?
  • Anonymous Mar 28, 2009
    The printer is still showing align please wait
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Does the machine ask you to "align" the print cartridges when you turn the machine back on? If the alignment page when finished printing is missing a key color (say yellow), then the alignment will not succeed.
Posted on Jul 29, 2007
SOURCE:
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
RE: HP 2110 all-in-one printer. I have put in a new Black HP toner cartridge (color is OK). The printer then goes through the "Align Print Cartridges" process. After the cover page (which prints...
Turn off the printer
Clean the Scanner Glass with Lint Free Cloth ( drop 2-3 drops of water on Cloth, Squeeze it and Wipe the Scanner Glass.
Also try to switch/change the Wallsock/Surge protector socket since the Scanner bulbs are not getting enough power to scan the page
Jun 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
HP psc 2110xi color printing problem
The printer head may need to be cleaned. You can buy a cleaning kit for the head.
May 08, 2009 | HP PSC 2110 Color Printer
Hp psc 2110 incorrect ink cartridge message.
Hi plabonne,
I hopped out to HP's support site for stats on your cartridge and found some info at this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=C8648A&jumpid=oc_R1002_USENC-002_HP%20PSC%202110%20All-in-One%20Printer&lang=en&cc=us
are you using an HP 57 Tri-color cartridge? HP printers work best with HP cartridges and often have problems with refilled cartridges. the grinding noise you're hearing makes me wonder if the cartridge isn't seated all the way in its little carridge (the plastic part that holds the cartridge). have you had a chance to slip teh cartridge back out and try gently slipping it back in again?
here's another link to try for info for this model of printer (HP's support site), with specifics about your error message about half way down the page:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu05206&dlc=en&product=79488
hope this helps!
-JW50
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
The printer is not recognizing the black print cartridge. It is an official hp black 59 (19ml) cartridge but it still does not recognize it and therefore will not print. My printers is an HP 1215...
Your printer does not use #59 Cartridge!!!!
HP 56 black print cartridge (19 ml) C6656A HP 57 tri-color print cartridge (17 ml) C6657A HP 27 low capacity black print cartridge (10 ml) C8727A HP 28 low capacity tri-color print cartridge (8ml) C8728A
Sep 24, 2008 | HP Office Equipment & Supplies
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
HP Deskjet 6980
Take a look to see if the printer Cartridge Carriage belt is hung up
or something else is jambed.
Sep 12, 2007 | HP PSC 2110 Color Printer
HP PSC 2110 All-In-One InkJet Printer Logo
445 people viewed this question
Clive
Clive
Thomas F. Schneider
