Set start for few sec then cut off
As tube light it cut off,have +b on HOT have 12v want to know where is stb5v is i see about 3v on microprocesser.when set start i heard sound then cut off .i can restart set with remote then it cut off .i do not have schematic
  • geoffroy1750 Jan 30, 2009
    TV Philips model29PT3223/69R Chasis 2K5
    Sergeant:
    Champion:
  • 346 Answers
I need the model and chassis number of the tv and the name of the tv
Posted on Jan 30, 2009
  • fred2chris Aug 20, 2011
    panasonis th50px80u
My car cut off while i was driving. I heard a ticking noise that sounded like it was coming from the engine right before it stopped.
I think you might have a timing belt that might be braking if it doesn't start your timing belt jump good luck
Oct 03, 2015 | 2002 Mitsubishi Galant
Engine cuts out when hot,rev counter drops to zero,ABS Hiss and Fl lights come on, now ABS light flashes,engine cuts back in after a few seconds,fault happens randomly.
Hi Kevin, this sounds like a bad ground connection to the ECM. Almost like it loses the ground and instantly reboots the system. I've heard of coil packs faulting when they get hot, but I don't know why it would effect your other systems if these were the problem. Good luck. I hope this bit of info helps you out.
Aug 16, 2015 | 2011 Honda CBF1000 ABS
Can't get temperature over 300 degrees. What could cause this?
If you are using a residential LP cylinder then the check valve needs to be reset. If not, check and adjust the carburetor shutters at the tip of the venturi tube and the set-screw inside the valve stem.
This will correct the issue almost always.
Sep 26, 2014 | Grilling
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Bad motor for pyg2300aww gas dryer?
How stiff is the motor? You can lube them sometimes and free them up for a while:
Aug 22, 2012 | Dryers
Samsung LCD TV 26
If you have not tried it you may want to see if the voltages listed come up with boards disconnected from the power supply one at a time---This could be anywhere from micro to the panel.
Mar 25, 2012 | Televison & Video
Just purchased the wheel set and within 200 miles had a flat on the rear wheel. When I removed the tube i noticed that the tube stem hole in the wheel is off center which caused a cut in the tube at the...
I have never heard of an offset valve hole. They sound like an expensive wheelset. I would go and try to look at another set of these wheels and see if they are all the same.
Once again, I myself have never heard of an offset valve hole. Hope you still have the receipt.
Sep 20, 2011 | Mavic Ksyrium Elite Wheelset
I have a universal ac adapter what size v should i set it at it has 12v,9v,7.5v,6v,4.5v,3v for a vector jump start 450amp m# veco12apc
It probably doesn't have enough current capacity to charge the battery inside the jump start. get a 12 v 1 amp or greater AC adapter
Nov 18, 2010 | JUMP START SYSTEM
My dash lights and my radio stop workin when i was installing a new radio, how can i fix this?
sounds like you have a problem with the power supply. Check the fuse. if ok, remove the new radio and check the power connection to the radio. if you cut into a wire harnis to find a hot 12v connection, you may have severed the dash 12v supply or knocked it loose . Take it slow and retrace your steps, but first check the fuse panel. You may have shorted out a wire without knowing it when attempting the install. lift the pos. lead on you battery the next time you play with 12v.
Sep 18, 2010 | 1994 Jeep Cherokee Country
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
