When a DVD RAM cartridge is inserted the draw closes and after a brief pause the draw opens again to eject the cartridge. The drive works fine with non cartridge mounted DVD RAM discs.
Hi, I don't know if you ever solved this problem - but I had the same thing on my SW9571CYY. The solution is to replace the small drive belt inside the drive ( It is very thin and doesn't seem up to the job it has to do). Just remove the two screws on the rear, then the seven screws holding the plastic cover with the springs on it (don't worry - everything stays in place). Lift the disk tray out and the little belt is towards the front. I used an old belt from a broken LG GSA-5163D that was lying around. I think it would be difficult to find the correct spare so some people have even used a "O" ring with a slightly smaller diameter than the original belt.
Hope this helps Dwane4444
Was this helpful?
Yes
No
Popular Solutions for Panasonic DVD BurnerII MULTI
I have lost my DVD burners. They light when I boot, they appear in my Bios and system list. They do...
(More)
I have lost my DVD burners. They light when I boot, they appear in my Bios and system list. They do not show up on ''my computer''. In System, I get a 'will not work'' message and a ''you have the latest drivers''. I tried removing the hardware and the drivers and letting the boot reinstall them, which it did, but they still don't work. device 1 Pioneer DVD-RW dvr 116-d device 2 TSST corp CD/DVDW TS H652M
My dvd drive is not writing dvds, it writes cds and used to write dvds but is not not. Everything...
(More)
My dvd drive is not writing dvds, it writes cds and used to write dvds but is not not. Everything else seems fine.
For some reason my Matsushita SW-9571-CYY is not registering both unused and closed dvd-r's. Could...
(More)
For some reason my Matsushita SW-9571-CYY is not registering both unused and closed dvd-r's. Could this be a driver issue and if so, where could I find an update for the drive?
