Question about RCA 35V432T 35" TV
Switches channels etc. on its own
This TV has gone bonkers. It comes on by itself sometimes. If I turn it on, it changes channels or goes into programming mode. This happens 100% of the time. I've tried taking the batteries out of every remote in the house, figuring a stray signal was causing this, but that didn't stop it. I've noted that some strain on the cable seems to have bent the cable jack slightly, but I don't think that caused this. Solutions appreciated!
  • Ted Marx Sep 12, 2007
    I beat the thing with a hammer, broke it to bits and bought an HDTV big screen.
    Best day of my life.
The optimal solution is classic American capitalism and violence at its best.  Get yourself a hammer - no, NO! not that one, a BIG one, and beat that piece of junk to bits and rejoice at the little "pop" when the vacuum tube explodes.  Carry the remains to the curb with the rest of the garbage.  Then go buy an LCD HDTV  (plasma even better) on credit since you don't have the cash, and move on.
Just pay the $25 per month on the card and rejoice.  You'll feel better.  We'll all feel better.  There is no debtor's prison.  I hope someday you'll join me, and the world can live as one.
Posted on Oct 18, 2007
You needed to replace the switches
Posted on Oct 16, 2007
    Sergeant:
  • 457 Answers
Perhaps your neighbours have the same tele and the same remote......its not unheard of they may be in the direct line to your TV. Other than that I cant see that a tele can do all this by itself. Im not being cheeky here it is NOT logical?
Posted on Sep 11, 2007
  • Peter Hirawani
    Peter Hirawani Sep 12, 2007
    Good on you I wish I had money to do that gee! good on you, least you never allowed it to stress you out congratulations and have a nice day.......
Have a Mitsubishi TV wd60735 the tv volume just increases to max by itself, sometimes won't turn on, sometimes no remotes will work it and I have to pull the plug to reset it to get it to come on, have it...
Sounds like your tact switches on the front of the TV are shorting out. Unplug the plug for the switches. if the problem goes away then try to clean the switches with rubbing alcohol, if still has problem replace switches.
Aug 27, 2010 | Mitsubishi WD-60735 Projection Television
RCA P52921 changed channels by itself and unplugged it to reset it and
Take batteries off the remote and check if it is the remote , otherwise it is a stuck key on the tv or the control board is gone,
regaards
Mar 31, 2008 | RCA P52921 52" Rear Projection Television
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Prima Tv problems
some of the tact switch of your tv are defective,or stock ,if you know how to solder, change all switches but be carefull of short circuit
Oct 13, 2008 | Prima CV1311 TV
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Nov 20, 2007 | RCA D52W15 TV
TV Changes Channels by itself
The keyboard switches are going bad part# 432P109010 (there are ten of them).To verify this, disconnect the connecting wire to the keyboard pc board and see if you still have the problem- the remote will still function normal- the green power led will not light up when you power on the TV with it disconnected so listen for the click and wait for the TV to power up when you use the remote.
Sep 18, 2007 | Mitsubishi WS-55807 TV
RCA 35V432T 35" TV Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
