Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Have a Frididaire side by side less than six years old. WAs running fine. I moved. During the summer months I would hear the motor like it would come on and off, on and off and then oneday NOTHING. I live out in the middle of NOWHERE. My husband is not an appliance repairman, but he is handy with tools and says he could probably fix it if we can get an idea where to start. Help.....
  • topplepslash Jan 30, 2009
    I forgot to mention one important thing: We had a storm that came thru and had a power surge. Then the fridge didn't chill down on one side and freeze entirely on the other. Now when you open it up, the lights come on and you can faintly hear a fan running. We are thinking it's a power supply problem, but what the heck?
  • 1,214 Answers
It sounds like the compressor is locked up, and replacement is the only fix. By any chance did you lay the refrigerator down when you moved it? (It's OK to lay them down, but only on a particular side which varies from unit to unit.).
The "nothing" noise you indicate is/was the start relay jumping in and out of the circuit. It' supposed to do this, and when the compressor runs, you won't hear it over the other noise. But when the compressor is locked up, then you will hear it pull-in, and then hear it drop out as the windings in the compressor overheat and break the circuit.
If the compressor starts, then the windings don't get as hot, and the relay drops out, and everything is fine.
Reply back your thoughts/questions.
Posted on Jan 30, 2009
  • Mark Egan Jan 30, 2009
    It sounds like the defrost circuit is having a problem.
    It could be any one of the following -
    Defrost thermostat
    Defrost heater
    Defrost timer
    I would be suspect of the timer, but all three need to be checked out.
    Are you saying the unit cools but doesn't freeze now? If so, disregard my initial response about the compressor being locked up.
I just purchased a new Frididaire side by side. I've had it 4 days. It runs about 13 minutes and is off about 11 minutes. Is this normal? Seems like it shouldn't run so much.
For a new fridge, need more time to maintain the required temperature of the fridge and mainly the goods in it? So everything seems normal. The time will be reduced day by day since the goods will stay for longer time in and door opening will become less and less.
So don't worry everything seems fine.
Oct 16, 2010 | Frigidaire Refrigerators
Our monitor (less than six month old) won't power up.
This is 2005 model, 3 year warranty. 6 months old?
You will need to open it up, first thing to look will capacitors int ehpower supply, main AC fuse.
Please verify if it is only six month old, otherwise, take it back to where you get it from.
Apr 06, 2010 | LG L1915S 19" LCD Monitor
I have a lot of 4' fluorescent lights that are
Why not ventilate the attic so it is not so hot during summer months. Joe
Mar 25, 2010 | Kitchen Appliances - Others
What motor oil weight should I be using on my 96 olds 88....we live where the winter temps can go as low as -10 F and as hot as 95F in the summer
5w 30 or 10w 30 during the winter. After an oil change... check your oil after 200-300 miles of use. Is the level the same? If so your weight is fine. If it drops, it's to light of an oil and your engine is now "drinking it" like fuel, move to a heavier weight. As far as Changing between winter and summer. Changing Oil weights is not bad for your motor so if the winter you go with 5w 30 and it works, great, shoot for the same during the summer. If it seems to "drink it" during the summer using this weight, go up to the next (10w 30)
That being said. Changing from natural oil, to synthetic, back to naturual , or vice versa... swapping back and forth between these KINDS of oil has been known to cause damage. so whatever weight you decide on, stick with one "type", natural or synthetic.
Feb 27, 2010 | 1998 Oldsmobile 88
My Sanyo microwave oven is six months old. The turntable has stopped rotating smoothly. Its motion has suddenly become jerky and noisy at the same time. I have given it to the vendor who sold it to me, for...
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty, as long as the problem is not due to grease or liquid spilled down into the motor.
Nov 29, 2008 | Microwave Ovens
Ice bucket will not come out
call the company to fix it, you have one year factory and labor.
Jul 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
102 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
