Why is the red light is always on?
Hi my imat jam red light is on and it won,t stop even if i release The battery!!!
The device seems to work properly but it has some problems with the computer!!!!(synchronizing)
Thanks
    Guru:
  • 832 Answers
Hi thanks for using fixya!!
You know what, I had the same problem with my Imate Jama 101, what I did, I click the master clear so that it will return to its default. Please try that just go to program and then you may find the Master Clear, just click it to restore factory defaults. If the problem still coming, you need to send your unit to service tech to check thoroughly the software, maybe it needs some updates and to correct the error.
Hope it helps, good luck! if you need further, let me know.
Pls. don't forget to rate my solution positively! thanks!
Posted on Mar 16, 2009
How to reset i-mate jama 101
Hi.
There are 3 ways:
1) Start->Settings->System tab->Master Clerar->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset.
Also there is a video on youtube which shows it to you.
http://mygsmtube.com/videos/198-imate-jama-hard-reset-howto.html
I hope this helped you. Thanks for using fixya
Jul 27, 2011 | i-mate JAM Pocket PC
I need drivers for my Imate K-jam phone
Hi
Thank you for your query
There are no specific drivers for the K-jam you only have to downlaod and install Microsoft Active Synch which can be found at
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
I hope this has been useful
Mar 15, 2010 | i-mate K-jam Smartphone
How can reset imate jama
1) Start->Settings->System tab->Master Clear->1234->ok
Feb 27, 2010 | i-mate JAM Pocket PC
Imate jam shuts down every now and then
hi thanks for using fixya!
On that kind of error, I suggest that you bring your phone to a service center to check further the software that you have. Be sure that you have change the battery even so that you said that it works fine. You already did the soft and hard reset, but unfortunately, still not working properly.
Good Luck! hope you still have your warranty!
Don't forget to rate my solution! thanks!
Mar 17, 2009 | i-mate JAM Pocket PC
Imate is dead after upgrade
go to http://www.imate.com register there and give your device info while registering and download WWE rom from there and istall it using active sync
krishna
Jul 21, 2008 | i-mate JAM Pocket PC
Imate jam back up battery is not cahrging...
i have imate jam if it is turn off when i turn it on then my all programs are delete and back up takes so much time. is there is an other solution
Jul 10, 2008 | Computers & Internet
My imate Jam wont powerup
Just put the charger in the device and then soft reset it light will turn to yellow. if this dosent work try to put the charger and then remove the battery and put it back to phone while the charger need to be remain connected.this is gonna work
cheers
Mar 05, 2008 | i-mate JAM Pocket PC
I Mate K-Jam
Hi There
it seems your phone is stuck in bootloder mode...try to hard reset your phone...and reinstall OS if required....
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Jan 11, 2008 | i-mate JAM Pocket PC
Imate jam problems with power n network coverage
Hi try a hard reset.. i think a firmware update will remove the problems !!
Jan 04, 2008 | i-mate JAM Pocket PC
IMate JAM battery drained off
When I bought my Imate I had the same problem. Put the charger on it and leave it for an hour or so and check the results. Just so the backup battery gains charge.
Sep 07, 2007 | i-mate JAM Pocket PC
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
