Question about Sylvania DVR90VE DVD Recorder/VCR
Hooking laptop to player for live feed
I have an older tv and want to play Hulu shows. How do I play them using the s video hookup on my Sylvania DVD player?
My yahoo email keeps logs out and am telling it to say for two weeks and my local zip code same way help.
Posted on Jan 30, 2009
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
Xbmc
Need more information to really help you. Are you playing movies in the DVD/CD player of the laptop? Are you playing movies by streaming from Netflix or Amazon or Hulu or Xfinity? Are you playing movies from an external hard drive or flashdrive plugged into an older USB 2.0 port?
Your wi-fi connection may be too slow to stream without freezing. Your cpu/processor may be too old and slow to handle HD video. Your video/graphics chip built-in to the laptop may be old and not capable of handling HD quality video.
Jun 10, 2014 | Acer Aspire Computers & Internet
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
Can I connect my laptop to my 51swx20b and watch hulu or dvds?
If your laptop has an S-Video output you should be able to connect your TV with the S-Video input (F connector) in the rear. You should be able to watch dvd and hulu if you have a good graphic card. But if you are looking to have something more permanent, I would recommend you a network-ready HD media player, like for example the Western Digital USB 2.0 WD TV Live Network-Ready HD Media Player. I have one of those and I can see HD movies that I download and put on my Usb, or I can see any media (videos, photos, music) that I have on any hard disk in the network. (Because the media player is connected to my router) The media player can work wireless if you install and additional wireless adapter. If your media player is Hulu-ready, you will see it immediately. The WD TV Live only has Youtube integrated. In my house, I converted my laptop in a Media Server with PlayOn and I can stream Hulu, CBC, CNN, etc. to my WD media player (in my case, wireless, but I want to connect them directly) and then to my TV (using a hdmi cable, you can also use a composite cable) It is about $230 in components: Media player ? around $130 Compatible wireless adapter ? 40$ (optional) PlayOn ? 40$ Cables and others ? 20$
Dec 15, 2009 | Hitachi 51SWX20B 51" Rear Projection...
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
Jul 31, 2009 | Sansui DTV3200 32" TV
Dvd hookup to phillips tv without inputs
Have yourself a VCR that has a Scart input, or Video in, and feed the DVD in there. Connect your TV to the VCR, and tune it in to the video channel, using aerial lead and tuner.
When you flick VCR to AV1 (or similar) you should see the DVD appear on the TV Video Channel :)
Mar 14, 2009 | Philips Magnavox 27MS343S 27" TV
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
May 03, 2008 | NexxTech N600D DVD Player
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Sylvania DVR90VE DVD Recorder/VCR Logo
81 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
