Question about StarTech.com StarView SV211K 2-port KVM Switch
The box super, picture problem
Hey, i have 'The box super' and have recently purchased a 42'' hd ready lcd tv. The picture quality is pretty poor. Its connected with a good quality scart lead at the minute. What is the best connection or way for to me to get a decent quality picture on my tv?
Thank you!
    Problem Solver:
  • 19 Answers
Check your scart to see if any pins are bent or even a slight bit of dirt will affect the quality of your picture
Posted on Jan 31, 2009
We have a 42" sharp lcd tv we have satellite with
Hi to get the full potential of your Flat Panel, you need to subscribe to a digital HD feed. most likely they will give you a digital box for HD.
Mar 27, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Instuctions connecting ps3 to hd ready tv
The answer is simple really. You can't connect your PS3 to your TV with a USB cable. You need an HDMI cable.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
CLEAR PICTURE ON MY 42
Dear LADY DAWN,
In order to get true high definition quality, you would want a high definition source. There really is not much else you can add to make your picture clearer, provided you have it hooked up with the best type of cables possible.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jul 21, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
FUZZY (SNOWY) PICTURE
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
Dec 24, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
StarTech.com StarView SV211K 2-port KVM Switch Logo
76 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
