Question about NetGear USB 2.0 108MBPS Adapter 802.11 (DHWG111T)
Installing wep ssid on smc wireless adapter
Dear Sir, I am installing SMC wireless adapter for wireless internet use. I am getting a red laop top icon on my task bar. I called my provider and they say that SME does not have wep settings to enter the security code. Can you please assist. My internet provider is bigpond/telstra which is the biggest in Australia. Do you have a contact tel in Brisbane Australia to call. Thanks
    Problem Solver:
  • 16 Answers
Phone number 133 933 found here: http://my.bigpond.com/help/contactus/techsupport/default.jsp
Posted on Jul 29, 2007
I don't have the installation disc for the SMC EZ Connect g SMCWUSB-G 802.11g Wireless Adapter. Is there any website that I may get it from?
Try this site to get the drivers for the SMCWUSB-G: http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&productCategory=5&modelNumber=1545&partNumber=0&downloadType=1&knowsPartNumber=false . You will need the part number of your adapter. Then choose your OS and click the blue button with the right arrow.
The manual and firmware are also available. See http://www.smc.com/index.cfm?event=viewProduct&cid=5&scid=31&localeCode=EN_USA&pid=1545 . The links for support and documentation are on the right hand side of the page.
I hope this helps.
Feb 22, 2013 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
I have installed a SMC2862W-G wireless usb adapater on my pc. it is recognizing my wireless router and it is showing a decent signal strength in the SMC utility. However, my wireless connection icon on my...
You need to install the driver disk that came with the USB adapter. Your PC correctly pointed out that the internal WI-FI adapter is not working but the USB adapter should be showing on the taskbar of the driver is installed correctly.
Mar 08, 2018 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC Barricade SMC7004VWBR not found by Wifi toys
good day,
hope this link below will solve your problem.
routers
Feb 12, 2010 | SMC Barricade 7004VWBR Wireless Router
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Repeater function
you make a device into ap mode you can get it
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
A D-Link to SMC Wireless Internet Sharing...
hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
  11. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Mar 18, 2008 | Computers & Internet
Smc 2632w drivers for use on a tosiba a-105-s1014
http://network.free-driver-download.com/SMC/14680/SMC-SMC2632W-V.1-Wireless-PC-Card-Driver-v1.32.1-Multiple-OS-Package.html
go to this link and download it and save it in the desktop>and double click on that automatically it will install follow the instrucyion >thx
rate me solved if its helps
Oct 25, 2007 | SMC EZ Card network Adapter
NetGear USB 2.0 108MBPS Adapter 802.11 (DHWG111T) Logo
104 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
