Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Two different error messages
My new Toshiba laptop recently clunked out. First it said an optical or removable drive was faulty, then it says my system registry is either corrupt or missing. Plus I can't even reformat the Hard Drive. Is there a way I can get it running without losing all my data?
  • 565 Answers
Try this first (I know your drive is "inaccessible"): Hopefully you have a Vista installation disk, if not download and burn this iso file with Img Burn or similar program:
Insert the disk in your drive even if you have to insert a paper clip into the little hole on the drive faceplate to open the drive bay door.
Try to boot into the Vista installation window. If you can do that, run the start up repair utility.
Please do not rate this post(s) until we have tried more solutions, as there are some other remedies, but try this one first.
If this doesn't work for you, please post back.
Posted on Feb 04, 2009
Toshiba m840
You're going to have to do a minor tear down to remove the drive to get the specific model number as there are at least 3 different types of optical drive available. You'd have to do this in any case to remove the old one and replace it.
Dec 04, 2013 | Computers & Internet
I have a 3yr old Toshiba E205-S1904, intel core i5 with windows 7. More and more recently the fans have been running hard when I play online games or do anything that uses a lot of cpu. It hasn't been a...
sorry i couldn't help with this, but you could use MEMTEST86+ to diagnose the ram just run make a bootable flash drive and run it overnight it's free
Sep 22, 2013 | Toshiba Satellite E205-S1904 Laptop
Getting error code F3 F100 0003 on a Toshiba Satellite L650 running on a Windows 7 Ultimate 32 bit operating system. This code appeared before hard disk drive was replaced and continues to appear after a...
Hi Lea,
If you're getting the F3 F100 0003 error on boot-up, the problem might lie on three things. It's either the a bad HDD, Memory, or the video adapter (which is soldered on the motherboard). Since you already replaced the HDD, the problem might lie on the other two. If you can burn a disc to run diagnostics on your computer, you can use UltimateBootCD or Hiren's Boot CD (more info on the tools here).
I've also seen some errors when you are trying to re-image the HDD using the Recovery Discs and it may have some connection to the error message that you're getting. Here's a list below:
-An error has occurred: ERROR : 10-FC10-1710" -- may be caused by a faulty hard drive.--An error has occurred. ERROR : 10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
-An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
-An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
-An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Hope this helps. Good luck.
Sep 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
Whenever i put some CD/DVD, it doesn't read at all and I receive this message "Please insert a CD in CD Rom" and there is yellow icon on the device as its drivers are not installed but when i...
Go into Device Manager and remove the optical drive from the list. Restart the computer. It should detect "New Hardware", identify it and install the correct driver.
What's going on: apparently there was a glitch or bug in the Windows 7 upgrade. The DVD drive is misidentified in the Registry as a CD-ROM drive, but it kept the old driver. Of course, Windows 7 thinks a DVD driver is incorrect, so it puts a yellow warning flag on it in Device Manager. It also refuses to acknowledge any disc in there except a CD (stupid computer!). So we need to get the incorrect info out of the registry before Windows will run the optical drive properly.
If Windows 7 gets stubborn about it, turn off the computer, look for the optical drive retaining screw, and take it out and physically remove the optical drive. Now, you should be able to remove the optical drive from the Registry. Restart the computer, double check that the optical drive is gone from Device Manager, then shut it down again. Put the optical drive back in the computer and turn it on. This time it should get everything right.
Jan 02, 2011 | Toshiba Satellite X205-S9810 Notebook
How do I get the BIOS to recognize a new optical drive (more advanced - has DVD R/RW capabilities)? BIOS reports IDE1 error upon POST. I put the old/bad one back and get no error, but cannot read CD/DVD
Go online to
There are several BIOS and Firmware updates to be done if you choose to use a different DVD Rom.
The web site is very easy to use and has a lazy mode! Log in your laptop and it will do all the work for you!!
Have a great Christmas
Dec 24, 2010 | Toshiba Satellite A45-S130 Notebook
Blank screen
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
Aug 01, 2009 | Toshiba PSAFGU-058002 Notebook
Atapi dh20a4p problem
OK... see if this:
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly K000888950 will work for you?
See eBay: 272402441049
$20 NEW ~ Including shipping from Denver.
The ONE thing that does bother me about this Auction is the word "BEZEL"... is it just the BEZEL without the actual drive? Please MESSAGE the seller and ask!
Final note: Be VERY careful about DVD Drives that are listed as "NEW" (other) ... MOST times that decodes to USED!
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly...
Nov 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
1780 disk 0 failure message
it's hard drive...most likely you are in need of a tune up.
check out this link, and you may find the Tuneup is just what you need.
Mar 17, 2008 | HP Compaq nx6110 PC Laptop
New Laptop Optical Drive Causes 0203 failure ide #2 error at boot
it's in the bios, hit F2 when it's booting, and go to drives, and set it from will see may need to turn them off, and then restart, then F2 again, and then turn them back on.
check your computers warranty here 4 FREE
Mar 13, 2008 | Toshiba Satellite A105 Notebook
Problem installing nec 6650 drive
Assuming the connection to the laptop has been physically made correctly and that your previous optical drive had the same problem. The motherboard of the laptop may be faulty in the way that the IDE channel may not be recognising any devices. Put your old drive back in to make sure it isn't a fault with the motherboard. It may be that it's a rare compatibility problem, or the interface of the NEC 6650 is different to that of your current optical drive. Failing all this. Reset your bios to the defaults.
Sep 06, 2007 | NEC ND-6650A DVD RW Dual Layer Burner
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
