Question about Sebo Automatic X1 Bagged Upright Vacuum
I have a Sebo x1. It will not pick up from the head.
The unit has had the filters checked, hose o.k.
The middle wheel seems to be at its highest level, and the brush roller is approximately half an inch from the carpet even in the cleaning mode.
After removing this wheel it seems to motorised, how does the machine adjust the wheel itself.
If the head is pressed down with my foot it seems to operate as normal.
Regards
K Hammond
  • Anonymous Feb 02, 2009
    Many Thanks,
    It would seem the wheel is operating when the head is put in cleaning mode-lamp is also lit while doing this.
    I was trying to vac a fairly thick rug, pile approx 20mm.
    Strange how it can't cope with this length of carpet. What does it use to determine fibre length electrically.
    Best regards
    Keith Hammond
  • 328 Answers
Hi
If the wheel isn't moving when the upright handle is swung down normally then the hydrallic action will be broken. The wheel only adjusts to the carpet when the handle is swung down and the wheel goes to the highest position. HOWEVER if you have large pile / thick carpeting then the X1 will struggle to pick this up as it doesn't cope well with thick carpeting. Sebo's G1 series with a manual adjuster dial is better in that respect. Put back the wheel as normal and check that it is lowering once the handle is unlocked. If it doesn't show up with the lights on the front of the hood showing that the wheel is going down, then its either the carpet thickness or the hydrallic wheel mechanism is broken. Contact Sebo in your country and they can usually send out a line diagram or suggest a repair.
Posted on Jan 30, 2009
The wheel underneath my sebo cleaner seems to be too high So not picking up right
You should have a dial or a lever to adjust the height. It is usually on the top of the unit or under the unit. Good luck!
Mar 13, 2016 | Sebo Vacuums
Tip
Useful Tips for Sebo's X1 Bagged upright vacuum.
Own a Sebo Automatic X1 Bagged upright or perhaps a Windsor-Sensor model? Here are a few tips to get more out of your machine.
When it comes to filter replacement, the standard cone/tube shaped filter can actually be cleaned by the Sebo if only just for a short moment just to get rid of any attached dirt the filter has accumulated. By removing the filter tube, the auto stop clip comes down, but by lifting your finger with this clip upwards and your other hand holding the bin door, the door can actually be locked back into position as it would normally. Then using the standard upholstery t shaped tool, clean the tube leaving it free of any dust and dirt contained in the tube. Once the tube has been cleaned you can take out the bin door and install the filter back in. Sadly the foam motor filter on the top hood cannot be cleaned or washed and has to be replaced.
If the filter tube however is completely stained and you dont have a free spare one to fit, the filter can actually be removed by removing the tie clips on the top and bottom of the holder. Wash the filter and dry in a tumble dryer - EBay in the UK sometimes sell filter squares which can be tied and locked to the cylindrical tube. Once the filter is dry you can then tie it up to the grid again and if the ties get lost, small computer wire ties are a suitable replacement.
Another feature of the Sebo X which has only just come to light recently with Sebo's user videos is use of the dry cleaning powder. Although Sebo don't actually tell you, by manually rubbing the powder into your carpet with just your fingers rather than raking it in on the top surface you'll get more out the first application of rubbing the powder in and letting it get a better chance of removing actual heavy stains. If you don't want to rub that powder in manually, remove the top hose by unlocking it where it meets the bag dirt channel on the left hand side of the machine at the top. (right hand obviously if you are facing the Sebo) then the Sebo X can be used as a rolling  brush to rub the powder in. After the 30 minutes minimum waiting time, lock the hose back into the X and vacuum up as normal.
This facility of removing the hose/thus cutting the suction is also very useful to rub in bicarbonate of soda into your carpets if you own pets. Bicarbonate of soda is an ideal natural odourizer which will maintain clean areas. Sebo's DuoP dry powder is ideal to do this as well for general stain protection if you like to keep your carpets clean.
The paper bags can also last a lot longer if the dirt your Sebo has collected remains half way at the top rather than naturally falling to the bottom of the bag.My X1 does this with new carpet fluff. Take the crevice tool and push the tool into the top opening of the bag to push the dirt GENTLY down - this will give you extra longevity on the bag used as well as not having to replace it so often.
There are ways to make your Sebo X1 cost effective!
on Mar 28, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Does not pick up at all there is no suction
Check that the hose is not blocked. Also check the dust channel air ways (see the orange trapdoor on the underside and push your fingers through to see if there are any debris blocking the suction.). Also check that the filter on board is clean - if it is completely dirty it needs replacing as well as the dust bag.
Nov 21, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
Hi. I have a Sebo X1 about 12 years old. Last time I used it there was an unpleasant smell in the room but didn't seem to be coming from the Sebo. However I am now trying to use it and it doesn't work. The...
The unpleasant smell could have been the lifetime belt finally giving up. Also happened on our 13 year SEBO X1 Automatic due to my error of vacuuming up a rug with long loose strands! If you are good with a screwdriver, you can replace the drive belt easily enough - go onto You Tube - there is an excellent UK video showing how to replace the drive belt on the SEBO. There are two belts, but you will know which one has to be replaced if you remove the screws on the underside of the main floor head. Before you do anything, kneel on the floor beside the SEBO and press the main release button on the bottom of the front bin area just above the floor head. It may need brute force but when pressed, put on knee on the floor head gently and pull the bin upwards to release from the body of the SEBO. This unlocks the main floor head from the bin, making it easier to look at the floor head. See video: http://www.youtube.com/watch?v=AOPphVcZHYA
Sep 14, 2013 | Sebo Vacuums
Full bag clog light
1.If your sebo is less than five years old, you have a reciept, and are not using it commercially, in most cases this machine will still be under factory warranty. To locate
an authorized sebo dealer simply call sebo or use the dealer locator on their website.
2. If it is no longer under warranty:
First i would pick up something small such as a balled up gum wrapper and make sure it makes it to the bag, more often than not something is not checked, and its still plugged. Heres how i'd check for plugs.
  • Pull the wand out and remove it from the hose by pressing the button on the wand look through the wand
  • Remove the hose from the machine by pinching the hose clamp and pulling the hose out (it simply presses back in when you are done)
  • press on the large button below the bag compartment on the front. (its often a different color and presses difficultly) lift the bag compartment and handle off the powerhead. (replace by simply pressing the bag compartment back onto the head)
  • look down the powerhead and inspect the other areas of the bag compartment.
  • open the orange/gray door on the bottom of the powerhead and look through checking for debris.
Simply go back up through the steps to reassemble.
If your test makes it into the bag just fine and you are not plugged, the tall filter inside the bag compartment would be my next suggestion and since you changed this it should not be a problem. This leaves few possible problems. Circut board error/Sensor error would be my next step. Essentally its one in the same, but there is no great way to test them without simply replacing parts. (an expensive proposition) The local sebo dealer will more than likely have a working used board they pop in and out to check for problems. Some dealers may let you use these others will require you either buy the parts or pay for labor.
*Bad boards in sebo/windsor products are extremely rare, my bet is always on a plugged filter or plug in general. Be sure to look carefully something as small as a toothpick surrounded by carpet fuzz can set them off.
Best of Luck
Jun 05, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Need Sebo x-1 parts
Hi
contact them direct they will help you out
SEBO America, LLC
7472 S. Tucson Way, Suite 190
Centennial, CO 80112
or look here
http://www.sebo-vacuums.com/frameset.htm?dir=Support
Please leave feedback for me
Thanks
Rob
Feb 12, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X1 vacuum not working
The X1 has a servo motor with gear box, this is what adjusts for height. Either something has jammed it, or
it has gone bad. You would probably be looking at a $80 to $100 repair, that is if the servo is bad. There also is a computer controller circuit board which could be the problem.
Mar 08, 2008 | Vacuums
SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
Feb 15, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
401 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
