Question about ViewSonic VP930b 19" LCD Monitor
Mi monitor vx1940w no prende - ViewSonic VP930b 19" LCD Monitor
Why does viewsonic monitor vx1940w dvi goes to sleep on windows 7?
Make sure the resolution signal sent out via the DVI is a valid timing signal the monitor can recognize.
May 20, 2014 | ViewSonic VX1940w LCD Monitor
Mi tele solo prende y dura un poquito y se apaga
mi vizio se prende y de momento se apaga y se pone ***** ademas no tiene sonido q puedo hacer
Mar 05, 2012 | Vizio L32 32 in. LCD HDTV
Mi monitor es el modelo E177fpc. Prende normal, el problema es que cuando acceso los botones de configuracion que se encuentran en la esquina derecha inferior, en vez de aparecer el menu, me aparece un...
Mi monitor es el modelo E177fpc? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Jan 26, 2011 | Dell E176FPC Monitor
Mi televisor se prende y se apaga tiene tres focos en la parte delantera uno dice lam temp power el de powewr parpadea y no se queda fijo que puede ser
mi tv ultravision hitachi prende y se apaga lo desconecto y lo conecto y prende y hace lo mismo y m parpadea la luz roja d temp q sera ?
Dec 09, 2010 | Hitachi UltraVision 55HDS52 Television
I have a VX1940w and when I turn it on, the light is dim and it makes a buzzing noise then turns off after about 30s. How can I fix this?
Open it up and look inside for bad capacitors (bulging top/seal) in the power supply, post back what you see inside so we can guide you further, see example of failed Viewsonic monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | ViewSonic VX1940w LCD Monitor
Mi acer verition no da imagen nada pero si prende
please translate it in english. i can't understand.
Mar 04, 2010 | Acer Veriton 5200D PC Desktop
Viewsonic VX1940w monitor comes on for a few seconds then turns off. Press the on/off button and then turn it on again, monitors only stays on for a few seconds then turns off.
vmesa, Do not feel alone! Your monitor's problem same as ten thousand other CCFL back-lit LCD monitors all over planet earth!!!! Yes, and I mean the exact same symptom as you have stated. Yes, it can be fixed, but you shouldn't look to software or drivers to do it. Read my and other monitor guru's FIXYA profiles to find out if you have what it takes to attempt DIY repair on your unit!!! Follow all links you find and visit YOUTUBE!!! After an hour or two of reading you will understand your monitor and what might be the real cause for it's Black or Blank n Black screen symptom and how to fix it. If your pocket is deep enough, then skip all the reading and use VX1940w for trade-in on new unit. 12fixlouie
Bye for now.
Feb 19, 2010 | ViewSonic VX1940w LCD Monitor
No prende ya mi monitor
Hola, Su monitor tine un problema de unidad de fuent la luz O la connector de VGA tiene unas pins dentro la connector danados.
1. puede chkar los pins
2. comprar una unidad fuente da luz
Si su monitor tiene una garentia por fabrica yo recomendar usted llamar esta fabrica para un reperacion.
Disculpe yo no puede escribe moy buen in espano espero que usted si entiendan.
Por favor vota moy bien para esta solucion si usted encauntra the solucion si ayunden.
Gracis
Atte Rulds2008 - GURU
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 24, 2009 | Princeton Digital VL2018W Monitor
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
ViewSonic VP930b 19" LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
