Where is the drain tube to check for ice or is there another potential problem?
The drain tube is located in the freezer section. Upon removing the pack panel, you should see a small nickel size hole at the rear bottom within a metal water catching area. Signs of a clogged drain is water at the bottom of the freezer or refrigerator cools insufficently. If your drain is clogged, you should see if in and around the drain-hole and can be become difficult at times
What is your original complaint?
-C
Fremont, CA
