Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer will not drain
Thank you. I have a kenmore washer, the style that load from the front; high output 4t. the washer refuses to drain, and has stopped when it gets to this part in the cycle. I have unplugged the machine, and got it to move again, although now the only thing i can hear is a motor noise from the washer with it still not draining.
  • nmgal Nov 24, 2007
    Same machine type and exact problem as tommy3's. Thinking it might be a plugged up pump, I took the front and back panels off (after draining the machine and disconnecting power and water hoses). After moving the clip that holds the hose to the pump, I could not get the hose to come loose???? Any suggestions?
    President:
  • 331 Answers
Tommy, you have debris in the drain pump. This will be a wet and messy repair, so be prepared. Unplug the washer before reading further! You'll need to look way down next to the floor at the bottom of the lower front panel. There are three "TORX" (star shaped) screws there, remove them. Lower the panel about 3/4" or so and tilt the bottom toward you, then set the panel and screws aside. Right in the front, you'll see the drain pump and drain trap. Look closely at it... there's a big black accordion shaped hose going into the pump, this is the suction hose. Another, smaller one, exiting the pump... this is the discharge or drain hose. If there's any way for you to do this, do it... you need to "pinch off" or clamp the suction hose as tight as possible to avoid dumping water all over the floor in the next step. If you can find hose clamp pliers like this... http://www.thetoolwarehouse.net/shop/media/KD-145.jpg , it'd be worth your while. Now that the hose is clamped off, see that 3 1/2" wide plastic housing the drain pump is hooked up to? You need to unscrew the drain trap access (counter-clockwise) then pull it completely out. Inspect the piece you just removed and remove any debris. Inspect inside the housing, look for socks, underwires, etc... and clean it out completely. Stick your finger into the pump intake and feel around for any debris. This should do it! Reassembly is the reverse order. Good luck and don't wear any clothes you treasure while doing this job. (should take ~45 minutes to complete)
Posted on Jul 29, 2007
Kenmore front washer seems to leave gunk with the clothes the drain hose did have a fair amount of gunk in it. Is there a way to rinse and unclog???
Posted on Jan 31, 2009
He's right. That is where your problem is. Trust me. It happened to me.
Posted on Nov 14, 2007
If you can drain the water from the drain line can there still be an obstruction in the pump? I thought an obstruction in the pump would keep it from draining through the hose.
Tal
Posted on Nov 11, 2007
Solution Guy. There are 20 ways to skin a cat and your worked. The only tweek I would add is instead of trying to pinch off the suction hose you should just unhook the drain line from the top of the back housing and snake it down below the pump and drain off the water. It was an easier solution for me. Thanks, Steve Davis
Posted on Oct 10, 2007
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore front load HE 4T error code 2F what does this mean?
Its been my experience this is related to the drain pump being plugged.
First, you need to take out as much water as you can. Empty the washer and then select drain with NO spin. It may help to drain water.
Second step, unplug your machine, and unscrew the front-bottom panel (there are three screws on the bottom, you need to go to the floor)
Third, there is a plastic cover for the draining pump. WARNING - There is still, water inside, so have plenty of towels handy!
Unscrew the plastic cover and there is a good chance you'll find the clog.
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Removing panel cover
Sounds like your drain pump is clogged.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Machine not draining
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
It's slow to fill
It's overfilling
It's underfilling
Hope this may help;
Aug 10, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 4t
Try the diagnostic test by pressing Drain/Spin button then press the Prewash button four time within five seconds. It will start to ignitiate the sequence for the inlet valve. The cold then hot then wash  then drain then spin. Hope this will clear the brain of the machine and you are good to go.
F&H means you have a drain clogged, or bad pump or bad inlet valve or pressure switch or the worst ccu.
Oct 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,301 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
