My washer is not dumping the water after wash.. I changed the timer same thing.. any help
  • Mark Egan May 11, 2010
    Please reply the make and model number of this washer.
    Make sure the drain hose is not kinked, and that there is an air gap between the drain hose and the drain pipe at the wall.
    Scholar:
  • 42 Answers
If your washing is "not draining the water ad mid or end of the (rinse/spin cycle)", the typical problem for this complaint is your lid/door switch (most likely) or the water pump (likely).
In general, lid-switches run about $15 and the typical "working lid-switch" should have a "clicking" sound when opening and closing the door (not all models). The water pump can also be the problem, but from what you've described, I would look into your lid-switch first. Timers are very rare and relatively expensive in comparison to other washer components. Who told you the problem was the timer?
Posted on Jan 30, 2009
My washer isn't going through the cycles like it should by itself it jus keeps on dumping water into the tub until u go change it over to where it starts to wash the clothes and then when it gets to rinse...
If it has a mechanical timer that clicks when you turn it--it sounds like the timer is bad. They have a little clock type motor that makes them turn. If its a digital type display--the control board will probably need replaced. Make sure both hot and cold water works on fill because if it doesn't fill all the way it will never finish a cycle.
Mar 22, 2015 | Washing Machines
Water won't drain from tub.how to change pump.everything else works fine. nothing pluged.
Does water drain when washer goes from wash to rinse or is it just at the end after rinse. It could be a switch on the cycle timer not working if it doesn't pump out at all. If it doesn't pump out at only the end maybe one of the cams on the timer that makes the switch to dump water is loose or broke.
Dec 30, 2014 | Kenmore 94702 Front Load Stacked Washer /...
Water won't drain
You can lay the hose to get water out put in bucket dump out than with it empty turn water off and start see if the pump start the pump down. It can be pump or the idems in washer blocking some water getting out and the timer could be gone check severl setting and see if that it.
Aug 12, 2014 | Daewoo DWDWD3011WW Front Load Washer
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer will not spin and empty tub
Have a new GE Profile Energy-star top load washer it has to be the worst washer I ever owned the biggest problem is the energy saver water level I can't wash a comforter and if you change the setting on the wash cycle it dumps your water and starts all over ok I can find away to deal with that but the water level I can't ether I need to move the water level up or I'm going to put this thing out along the road on trash day and it's only 4 months old so I would like to move the water level up
Dec 26, 2010 | Washing Machines
Washing machine was working fine, but leaking water from the bottom. took it to a repairman, he said pumpwas stopped up and he replaced it. hooked it up and it fills with water but it will not start, wont...
if the washer machine idetifies the levels of water (ex low middle high) means that pressure switch works
there are two things!!!!
the switch's door is not working or the switch's timer also doesnt work
if the washer machine doesn't idetifies the levels of water does the problem
CHECK ALL THIS AND CHANGE WHAT IS NECESSARY!!!!!
Oct 05, 2009 | Roper RAS6233KQ Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
