Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
Hotpoint WD440G In wash cycle and blows all household plugs
Cant get water out as everytime switch plug on its blows!! HELP
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Syphon out the water by getting the end of the drain hose into a basin and putting it lower than the water level. a few shakes usually gets it flowing. you probably have a short circuit. my guess would be the heater box/element to start.
Posted on Jan 30, 2009
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Everytime we switch on at the plug, the fuse is blowing
check wheather before switching on the cycle it's going means
1)problem in your main supply to board.
if it is blowing after switching on the cycle before starting the washing means
1)problem on the heater.
if it's blowing after washing cycle means
1)problem in the wash pump/heater.
Jan 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Wd440g Hotpoint - in wash cycle and is blowing all the household
you will have a short circuit somewhere. usually the dryer box, but to get the water out you need to put the end of the drain hose lower than the water level into a basin to syphon it out.
the heating element of the dryer sometimes come loose on these machines and can be the cause of a short.
Jan 30, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
125 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
