Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Multiple lighting circuits on one timer.
Can I use a timer to control more than one light circuit. I got four circuits.
Thank you.
  • Anonymous Mar 17, 2014
    We have a Tork 11o1 timer that controls a Pump Fountain in a pond. We want to add lights to come on in the early evening and for both Pump and lights off at the same time. What unit should use. Its a 110 circuit 12-2
  • 37 Answers
I am not sure if you can buy a four pole timer, but if you can find one you would be able to do this. I've only ever seen a two pole timer however. The next option would be to get a four pole contactor with a 120 volt coil. You could run the timer off of one of the lighting circuits and the timer would operate the coil on the contactor.
Posted on Jan 30, 2009
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Programming to command other switches
Question is not clear.
Add a comment and say specifically what timer you have and what type of switch(es) you want to control, and add what voltage you are working with and what color wires you have.
You posted under Leviton 6230 30-minute countdown timer.
Generally, a countdown timer is not considered a programmable timer since the countdown program is already inside the timer.
With countdown timer, you push a button that turns circuit ON, and after countdown expires, the circuit turns OFF.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6230
Countdown timer can easily switch a contactor ON, and then turn it off after countdown expires.
http://waterheatertimer.org/H230A.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Leviton 6230M Decora Four Preset...
My yard stake is a tower with 6 outlets and a single button to set, the brand is Holiday Living. I can't get it to come on at dusk and run for 4 hours without the lights blinking. I want a constant...
Put black tape over photo electric eye and see if lights stay on without blinking.
Dusk-type yard stake has photo electric eye, which is visible as round glass ball.
Lights from circuit can cause photo-eye to think it is daylight, so circuit turns OFF.
Moment later, photo-eye thinks it's dark and lights click back ON
Usually 6-outlet yard stakes have 4 top outlets controlled by timer.
Normally bottom 2 outlets are ON full time.
Make sure bottom outlets are not blinking also, which implies problem with outdoor circuit or basic timer problem.
Check circuit with inexpensive circuit analyzer from Home Depot electric department.
Photoelectric eyes go bad easily, but usually they don't blink.
They stick ON or OFF.
Nov 29, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hello, I have a Tork K600Z astronomic timer which has 6 sets of contacts off of a relay for each. We've burned out the first two releys since the original installation about 7-8 years ago. We've tried to...
Sounds like you need to reprogram timer ....
K series is a multi-channel timer.
If you have 4 relays, then you have 4 channels, and each must be programmed separately.
6 relays, 6 channels.
Each channel controls one of the relays. This lets the timer control multiple circuits such as lights etc, each with a different programming schedule.
Each relay has 3 wiring terminals that are dry until wired with voltage.
Following links has manuals and resources:
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#K-series
Intermatic makes a similar series of multi-channel timers, with 1-2-8-16 channel models:
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET70000
Jun 29, 2017 | Hardware & Accessories
Hi, I aquired a traffic light....and i want to find a timer that would work the red yellow and green light....like turn the red light on for 30s then turn the red one off and turn the yellow one on for...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A lawn sprinkler timer might have some features you want: for example a timer that turns off one circuit, and activates another circuit. The problem is finding a sprinkler timer that cycles a few seconds between changes. Sprinkler circuits are 24V.
http://www.sears.com/shc/s/p_10153_12605_07106943000P?vName=Lawn%20&%20Garden&cName=Watering,Hoses&Sprinklers&sName=Watering%20Accessories&sid=IDx20070921x00003a&ci_src=14110944&ci_sku=07106943000P
Countdown timers control 1 circuit but the shortest time is 5 minutes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Interval timers control one circuit, and don't offer short times
http://www.intermatic.com/products/grasslin/interval%20timers/electronic%20interval%20countdown%20timers/et616.aspx
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Timers on the market by Intermatic, Paragon, Woods, Tork, Sylvania, GE all meet a home-driven mass-market need. There isn't a home market for a timer with short cycles ... there are probably home products that have similar circuit, like garage door openers or alarm systems but the circuitry is product-specific.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You might try an electronics forum > those guys can design and build anything
http://www.electro-tech-online.com
Sep 15, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Lights won't go on
Sounds like the timer may not be getting power.
Turn the circuit breaker that supplies the circuit OFF then ON, as sometimes it's hard to tell if a breaker has tripped by looking at it.
It's possible that the circuit is controlled by a switch that someone may have inadvertently turned OFF.
Also, it's very likely that the circuit is fed from a GFCI receptacle (the kind with the test and reset buttons that are usually found in kitchens and bathrooms) that may have tripped. Those receptacles can sometimes be found in very obscure places. Check outside receptacles too.
If anyone has been digging in the yard or flower beds it's possible that the cable may have been damaged.
May 31, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Install a timer to control pool operation
Another option would be to get an electronic timer like the Intermatic P1353 that has 3 circuits on it that you could program to cut on and off at different times. For example, you could have one circuit that controls the pump and turns the pump on, then the second circuit would turn on the booster pump at a set time after the filter pump had come on and then the heater could be set to also run at a preset time after the pump circuit was activated. Since the pump, booster and heater are all 220, it's a straight forward hookup with everything in one timer box.
The lights, as stated before, would be on a separate circuit (110) and have its own timer or photosensitive eye set in line.
May 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have 1996 Dodge Gran Caravan, and it gives me these codes: 27 and 43, what do they mean??
CODE 27 - Injector Control Circuit, output driver does not respond properly to the control signal
Code 27 MIL light options: OBDII
P0201 - Injector #1 Control Circuit
P0202 - Injector #2 Control Circuit
P0203 - Injector #3 Control Circuit
P0204 - Injector #4 Control Circuit
P0205 - Injector #5 Control Circuit
P0206 - Injector #6 Control Circuit
CODE 43 - Cylinder Misfire, or Ignition Primary Circuit
CODE $# MIL options: OBDII
P0300 - Multiple Cylinder Misfire
P0301 - Cylinder #1 Misfire
P0302 - Cylinder #2 Misfire
P0303 - Cylinder #3 Misfire
P0304 - Cylinder #4 Misfire
P0305 - Cylinder #5 Misfire
P0306 - Cylinder #6 Misfire
P0351 - Ignition Coil #1 Primary Circuit
P0352 - Ignition Coil #2 Primary Circuit
P0353 - Ignition Coil #3 Primary Circuit
Feb 03, 2010 | 1996 Dodge Caravan
I have a T103 Intermatic timer controlling the circuit for outdoor lighting. I used it to replace a wall timer with inadequate capacity (was designed to control a lamp or similar). Problem is that when the...
Let's review your wiring. There's probably something miswired when you get symptoms like that. Let's work one circuit at a time.
For circuit #1, the incoming (LINE) black (hot) wire is connected to the #3 terminal. The white (neutral) is connected to the "A" terminal. The bare equipment grounding wire is connected to the "GR" terminal (the green screw on the case).
The outgoing (LOAD) black wire to the first set of lights is connected to terminal #4 and the outgoing white (neutral) wire connects to the "A" terminal. The outgoing bare wire to the lights goes to the "GR" terminal. It's best to twist the wires together with a pigtail, wirenut them and connect the pigtail to the "GR" terminal.
Now for separate circuit #2. The incoming (LINE) black (hot) connects to terminal #1. The incoming white (neutral) connects to terminal "A". The incoming bare wire connects to the "GR" terminal.
The outgoing (LOAD) black wire to the 2nd set of lights connects to the #2 terminal. The outgoing white (neutral) goes to the "A" terminal. It's OK to twist all the white neutral wires (incoming _and_ outgoing for _both_ circuits) together with a pigtail that goes to the "A" terminal. Use a red wirenut.
As long as you don't load the 15 amp breaker over 12 amps (this is considered a continuous circuit and it cannot be loaded over 80% per NEC), you don't have to have two circuits if you don't want too. Figure about 1 amp per light as long as the lights aren't over 100 watt. (100 watt lamp/120 volts = 0.83 amps (round to one amp)
Jan 02, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
273 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
