Question about Samsung (SD-612) Internal DVD Drive
My ide dvd-rom is not working properly and i need drivers for it
  • 217 Answers
Consider downloading and installing driver scanner it scans for the outdated drivers and helps download it automatically without having to search.
click here to download driver scanneer:
you will be required to extract the file using sevenzip:
click here to download sevenzip
Posted on Feb 06, 2009
I need driver for Hitachi GD2000 2X ATAPI/E IDE DVD-ROM Drive to complete a win7 install
You're not going to get an install then. If that is NOT an OEM Install disc, you might have to try another drive to do the install with. Most ATAPI/IDE Drives are run by the BIOS.
Feb 01, 2014 | Compaq HITACHI GD2000 2X ATAPI/E IDE...
Dear , sir now i have only CD driver . can i change or put DVD driver for my computer.?
Yeah,you can do that,get an IDE interface DVD ROM .Ask the shopkeeper for an IDE interfaced DVD ROM only,be aware he may give you a SATA compatinle DVD ROM.
Thank You.
Mar 21, 2011 | Computers & Internet
My dvd rom not detected because it is corruped or missing device driver so can i do plz tell
There is no need for drivers for your drive, since Windows already have the necesary drivers for the cd/dvd drives. Either your drive is not working properly or the settings at the bios are wrong. In order to provide more helpfull tips to check out, clarify me these:
1.What kind of connection does your drive has? IDE or SATA? For IDE you will notice a long connector (with 2 series of 20 pins) at the back of the drive near the power connector. For SATA there is no long connector but a small one with just 7 pins.
This photo might help you:
2.Does your computer had another cd/dvd drive before? What kind of connection (IDE or SATA) did this drive had?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 01, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
I need drivers for a memorex internal dvd rom 16x Model MRX-210L-v1HM61 I think the part number is 32023254
If you have your Resource CD, you should install it and run the drivers tab.
If you do not have the resource CD, go to Dell's support site for this GX270. You can download the drivers there. You will be looking for the chipset driver and the IDE controller drivers. The CD drivers are firmware.
Mar 27, 2010 | Memorex (32023254) Internal DVD Drive
My dvd writer was working perfectly but when i format my wondow now it is playing only cds & when i insert a dvd it is not giving any response & my driver is also showing as cd-rom
When you formated you erased the driver you need to use your dvd writer as a dvd writer and player. If your dvd-rom came with a cd use it to reinstall the driver and program it uses. Otherwise you can search for your driver thru the manufacturer website or go to and find it there.
Dec 17, 2009 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
Dvd dont show in my computer
check your IDE or sata connected properly inside your CPU...
Jun 18, 2009 | Acer Benq 16x DVD and 40x CD-ROM Internal...
Cd rom recognised as cd audio
They will definately need drivers to be able to give out 100% of the performance.
You definately might have receive a disk while purchased the CD/DVD ROM.
Try that driver once and see the difference.
Jun 03, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
My LG Combo is not working after i have installed another LG Dvd Writer
I am assuming they are both on the same ide cable. If so set both of the jumpers to CS (cable select) and try rebooting the machine.
If this doesnt work you might have the bios configured to say there is no drive on that ide channel location. If the first option doesnt work let me know and I might be able to help further
Feb 11, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Samsung (SD-612) Internal DVD Drive Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
