Question about GE Monogram ZDI15C Automatic Icemaker
Ice maker won't shut off when full
The motor is grinding because it is continuing to produce more ice but the bin in totally full of ice---running over with ice
  • 1,800 Answers
Check the Shutoff Arm:
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown belowIce maker won't shut off when full - ef280e4.jpg
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
Posted on Jan 30, 2009
    President:
  • 2,559 Answers
You have a small bar that is on the side of the ice maker,just pull it up to the top of the ice pile,(If it click into place at the top,you went to far,just push it back down a little.
Please rate this a fixya
It will not shut off. Just keeps making ice ?????
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Mar 23, 2015 | Refrigerators
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
Ice crusher not turning
Make sure the temperature is correct. Most ice makers have to work in an environment specified in your manual. If the low freezer temperature is not reached your problems start. Try this first.
Jul 08, 2009 | Frigidaire FRS6R5ESB
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
You can take the cover off of the icemaker and with a pair of needle nose plires take off the dile and clean with an eraser. You probly can see the problem when you get the dile off. Let me know if that is works. Has worked for me in the past.
Dec 20, 2008 | Jenn-Air JSD2789GES Side by Side...
U-Line undercounter frost free ice maker refrigerator
All units made today have defrost timers to clear ice from the evaporator. Some of the ice sublimates...turns directly into humidity in the air in the box. It re-condenses in the ice tray area. It is possible that nothing is wrong other than excessive opening of the bin area or the defrost timer is running slow and staying on too long. You may also be consuming the ice too slowly. Can you either change the amount of ice in the bin by adding something to simulate part of the ice content or shut off ice production against low demand?
Dec 18, 2007 | U-Line Icemaker
Ice Maker Not Producing Ice
Have you reset the power? Is the bin fully inserted in the cavity? Are there any shutoff or bin full indicators that are not in the run position?
Dec 09, 2007 | Sub-Zero 632 / S
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
GE Monogram ZDI15C Automatic Icemaker Logo
1,460 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
