Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
CLASS HD Convergance ploblem
43" CLASS rear projection tv the convergence has gone. i used the convergance setting in the menu but did not work. ?
    Genius:
  • 1,550 Answers
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Posted on Jan 30, 2009
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Samsung PCL541R 54" Rear Projection...
I own a 60PP9401 60 in. Rear projection tv. My red convergance was way out of line. I placed tv in the shop a while back,cost me $300 to get it fixed! Got set home, red still out of line,but not as bad. My...
This set has an advanced menu for adjusting the convergence and what may have happened is the shop adjusted it (It is done with an original Philips remote) and then not SAVED THE ADJUSTMENTS INTO THE SET'S MEMORY.
I can if you have the remote get into the menu and adjust and SAVE the adjustments. If the set is HD the convergence will have to be adjusted two times, once in regular and once in HD.
Let me know if you have questions.
SD TECH
Jan 10, 2011 | Philips 60PP9401 60" Rear Projection...
Image on screen looks concave(middle of screen looks farther away than left or right side.)
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
May 27, 2010 | Toshiba 43HX70 43" Rear Projection...
My tv screen is slightly tilted.
I belive it is a convergance problem. If there is a auto convergance function in the setup menu try it out. If that doesn't work I would clean the lenses with qtips and alcohol.
Mar 09, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I can't find the settings in my toshiba 43VJ22P menu to adjust my convergance, please help!
you need to press must on the remote and whilst holding mute, pess menu on the left hand side of the tv. that will let you in to service mode. im sure if you press 7 in service mode it will let you in to the convergence menu.
Dec 22, 2009 | Toshiba 43H70 43" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Convergance problem
Hi, I`m assuming your going into the menu and trying to adjust convergence and the lines won`t align? If so the convergence IC`s have failed and that circuit will need to be checked to see which parts have failed and then replace them, probably time to call in a tv tech for that one, video-tek
Jun 09, 2009 | Samsung HCN436W 43" Rear Projection...
Colour convergence on a projection TV
hello it sound like convergance chips may be the problem
shaun
May 11, 2009 | Philips 43P8341 43" Rear Projection...
IC problem
You can manualy set convergenge by going into the service menu. Save and its ok. If it is not, convergenge ic gone and you must replace it.
Nov 16, 2007 | Samsung HCN436W 43" Rear Projection...
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
