Question about Sabrent SBT-RDIT PCI IDE Silicon Image RAID Host Controller Card RAID 0/1/0+1(For Both Low Profile P... (1801019)
Pci ide controller for third hard disk i have connected a third hard disk160 gb in my desktop via pci ide controller card in windows xp. hard disk is not being recognized. i have two hard harddisk 80- gb and 160 gb working fine.can some one help to solve this.
  • 1,800 Answers
First u shud check if the BIOS is detecting ur new HDD.
if its not u can activate the new port through bios in the advanced peripherals options sectin :)
Posted on Jan 30, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Cant find driver for SimpleTech 250gb external hd. Is it available?
Should not be necessary. It is recognized by the system automatically. Try connecting to another port, check the data cable and the connection to the unit, it may be corroded or loose.
Sep 13, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
I formatted my hd making it slave in other system: now i m placing it back on my system then it is saying Primary IDE masterNONE; Primary IDE Slave SP0822N Then comes NTLDR MISSING
> formatted my HD
This deleted 99% of the files on the disk-drive.
> Primary IDE Master: NONE
> Primary IDE Slave: SP0822N
Good. Your motherboard has detected ONE disk-drive.
Do you have just one connected disk-drive on your PRIMARY channel, or do you have two connected disk-drives (via the 2 connectors on the one ribbon-cable on the PRIMARY channel) ?
If you have two drives connected via one ribbon-cable, you MUST set the 'master/slave/cable-select' jumpers on BOTH disk-drives, to identify which of the two will be the 'master' and which will be the 'slave'.
Also, check that the 'second' disk-drive is getting electrical power.
Like I said, you deleted 99% of the files, including the 'NTLDR' file.
Your computer is trying to "boot" from the 1% of the files that still exist on the disk-drive, but cannot find the now-deleted file.
Perfectly normal, given that you have formatted the disk.
Oct 06, 2010 | Samsung (SP0822N) 80 GB Hard Drive
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Reagarding some Hard disk
You system probably supports IDE hard disks up to 200GB in size. It all depends on what chipset was used on your motherboard. Since it is a PIII system, the 200GB limit is most likely quite solid. Although, you can get past this by installing a PCI card that can handle larger capacity drives. You could also opt for using a SATA controller, but you will be limited to SATA-150 instead of the more current SATA-300 with a PCI interface.
Jun 07, 2009 | Intel P4 System Configurator (P4SDRAM1) PC...
Harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
I still cant figure it sound...
Uninstall Previous Sound Drivers & Install new one. I am online now & can help you out with remote assistance.
Aug 06, 2008 | Computers & Internet
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Sabrent SBT-RDIT PCI IDE Silicon Image RAID Host Controller Card RAID 0/1/0+1(For Both Low Profile P... (1801019) Logo
165 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
