Question about HP vs19 (Silver) 19" LCD Monitor
No Power Hello everyone, I went to turn on my pc this morning and everything came on except the monitor. I check all connections and the power surge and wall outlet. It's a HP VS19 monitor. Thanks
  • gooch797 Dec 06, 2007
    Same problem here. I left the computer on overnight and when I checked it the following morning, the monitor was off. No power and the Power LED won't come on either. The cord and power strip are not the problem. This is the second HP Vs19 to do this. My first one went out after 11 months and was under warranty. HP sent me a replacement and it did the exact same thing 3 months later.
  • Jack 1234 Dec 07, 2007
    Same thing, same monitor. Found mine DOA this morning. Tried everything. HP must be living up to their old standard.
  • 624 Answers
There is a whole lot the typical user can check but here is the list: -Disconnect the power plug from the power strip and plug directly into a tested wall socket. Sometimes the power strip sockets go bad. -Try another working power cord. -When you plug in the power cord do any of the monitor LEDs com on?
Posted on Jul 29, 2007
  • Anonymous Jul 29, 2007
    My post above should have read "There isn?t a whole lot....."
SOURCE:
Hello when I turn on my monitor and computer this morning I have a black screen on my envision monitor and the green light keeps blinking do you know how to fix this
Unplug everything from the tower. Including power cord.
Press the power button for 5 secs.
Proceed to connect, power line, mouse, keyboard and monitor
That should reset the power or hibernation mode that you might have issues.
If everything looks normal, proceed to connect your remaining devices.
You must be aware that having a BIOS settings to boot from USB, DVD or USB-FLOPPY might prevent to boot into windows.
Feb 24, 2015 | Envision Computers & Internet
Hp pavillion a850y
It is unlikely to be the switch itself. Check that the memory is seated correctly on the motherboard, as it won't boot without it. Otherwise it sounds like the motherboard itself is shot. Sorry for the
Mar 28, 2014 | HP Computers & Internet
Power to house went out during area power outage. Everything came back on except the computer? Tries to restart by holding power switch in, unplugged and replugged power cord - no response on monitor. ...
When the power is returned after a power outage it can cause a power surge and damage electronic equipment such as a computer. This is a reason to install a surge protection power board and connect your computer equipment to a surge protection board.
The switch mode power supply may be faulty and replacing it may get your computer operating again.
If you cannot DIY then ask a friend or take it to a computer repair shop.
Jul 14, 2011 | HP Pavillion s7420n PC Desktop
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
The power went off in my house for 15 minutes. When it came back on everything worked except the Gateway PC with Windows XP and the monitor which was connected to a surge suppressor. The PC won;t come on...
If the monitor is out as well then the surge suppressor did its job and took the hit, basically rendering it useless now, try plugging in the system and monitor directly to the wall, it they work then you need to replace the surge suppressor.
Sep 19, 2009 | Gateway GT5220 PC Desktop
My acer screen just went blank after i turned my computer on this morning. it stayed white....
Loose Connection Possibly. If not try Unplugging from the Electric.Leaving for a 5 Minutes. Then plug all cables back in and try again.
If this dosn't help then you may have had a power surge. Its hard to say what has happened if you have had a power surge, they can do all sorts of things
Aug 16, 2009 | Acer 22" X223w LCD Monitor
Turned off compaq presario desktop and now it wont turn back on. I used the start menu to shut down. Everytime I press the power button a light flashes over a symbol that looks like a lightbulb. Help
Try the following:
1. If connected to surge protector, make sure it's on. If it is, then...
2. Try plugging computer directly into wall and turn on...if no then...
3. Unplug and plug the power cord back in and then try to turn on...if nogo then...
4. If there's a switch on the back of your pc that has 120/240. Switch it back and forth back from 240 back to 120, turn on again...if no go then...
5. Unplug everything from the back of your pc except power cord, keyboard, mouse, and monitor. Try again. If it still doesn't turn on.. let me know. By chance, has any power outage occured or any change been done to pc since it was last turned on?
Dman
Jan 08, 2009 | HP Compaq Presario SR1123WM PC Desktop
Compaq Desktop won't start after city wide power failure
Dear! format your system and istall drivers after individual reboot ..
by khalid (Kashmir)..
E-mail:[email protected]
May 05, 2008 | Compaq Presario S6300NX PC Desktop
My monitor does not turn on
there is power problem  in your monitor.check the fuse,regulator,and horizontal output transistor
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
119 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
