Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
No sound when phone rings
When my phone rings there is no sound. its not on vibrate and the ringer volume is set for high.
  • 9 more comments
  • robin mckinley Jul 29, 2007
    problem solved - software issue
  • noirie Nov 08, 2007
    my phone does not ring when theres an incoming calls and yet its not on silent or vibrate mode. When i try listening to ring tones no sound and yet its playing
  • Anonymous Nov 14, 2007
  • loveabby Nov 15, 2007
    No sound from ringtones when the phone rings or when trying to set a ringtone, alarm doesn't work either
  • SB30 Dec 06, 2007
    I am also not able to hear any sounds on my phone. Not set to silent or vibrate.
    I noticed that there was a solution to this problem listed as "software" issues or problem. Is there any way to find out what that software problem was to see if it would work for the rest of us?? OR anything else that would work. The problem seems to come and go for me. Sometimes there will be sound and sometimes not. Right now there's no sound and it's very frustrating!!!
  • Dlit99 Dec 12, 2007
    I have this SAME issue. Has anyone found a solution?
  • Anonymous Dec 13, 2007
    brought it into ATAT and they tried everything they could, and said it's in the phone.
  • olademeter81 Aug 30, 2008
    no soun when is ringing
  • DWales Dec 14, 2008
    Same deal here - worked for over a year (verizon purchase 2007) and now I have no ring sound, no music sound, nada. What is this software problem one of you noted? Or is it a problem with the external speaker? Seems to be happening with most Krzr's across the web.
  • Anonymous Mar 28, 2014
    No sound when i get call, or alarm rings, get message. The volume setting is set to Max and is not in silent/vibrate mode
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Posted on Dec 12, 2007
  • 72 Answers
Problem solved.
Posted on Oct 18, 2007
4 Suggested Answers
SOURCE:
prashant2012
  • 1127 Answers
SOURCE: i have no ringing sound on phone, i have gone to
Hi
Check your volume level may be its mute, Increase your volume level and enjoy the sound
Posted on Jun 04, 2011
SOURCE: RAZR ringer (speaker) doesn't work
the speaker inside the phone is in mis contact or it is dead .. try changing the new speakers into it ... it will work ...
if u are not gud at servicing then visit the technician........
Posted on Feb 11, 2008
  • 33 Answers
SOURCE: the ringer doesn't ring, only
First, make sure your Jitterbug is open and confirm it's on.
Next, Press the volume button on the outside of the phone below the Outside Display. Press the top of the button to increase the volume and the bottom of the button to decrease the volume.
There are several ringer options available to choose from. If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 and they will walk you step by step through the process.
Posted on Dec 30, 2010
Jitterbug flip won't ring. I've checked the volume and it's set at maximum What is the Jingle, I've tried both ways, no help. Exasperated, donna
Page 30 of manual at the link shown suggests a way to silence the Jitterbug.
http://www.specsserver.com/CACHE/FREOWQFWSXOG.PDF
Quoting from Page 30:
To adjust the ringer volume:
1.
Be sure the phone is open and on.
2.
Press the
Up/Down
volume button
display window. Press each time you want
to advance to the next choice.
These choices will appear on the screen:
- Ringer Volume Ring Max
- Ringer Volume High
- Ringer Volume Med
- Ringer Volume Low
- Ringer Volume Silent
3.
When you're satisfied with the setting,
release the volume button.
Your Jitterbug may ring and vibrate
to alert you to incoming calls. The
ringer and keypad can be silenced
by pressing the volume button
Down
until
"Silent"
appears on the screen. Your
Jitterbug will now only vibrate to alert you
to incoming calls (This can come in handy
at a movie, a library, or any other location
where a ringer may be a distraction.
May 09, 2018 | Cell Phones
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
My phone doesn't ring to maximum volume, its too low.
Welcome to FixYa
Dear User,
You can Adjust your Ringer Level to High...If your Ringer is in Full Volume and No Sound/Bad Sound-the Problem is with Buzzer or Board Complaint[Board complaint in Rare Case]
Ringer Option in 6300:
  • Settings
  • Profile
  • General
  • 'Personalise'
  • 'Incoming Call alert'[Must be in RINGING]
  • Move to Bottom 'RINGING VOLUME'[move to Right side-now you can Hear Sound-Set to High Level or as you Like
  • It may ask for Confirm Selection of high Ring Vol
  • Alert For 'ALL CALLS'[at Bottom]
  • 'Save' Click
  • Then Activate GENERAL
You are Done[In this way -you can Select any Profile]
Hope this Helped -Dont forget to Rate ME......Thanks for Contacting FixYa...
Jul 09, 2010 | Nokia 6300 Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Thank you for visiting fixya
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
SOMEHOW MY PHONE RINGER IS OFF, SAIS "SILENT MODE". nOwhere in settings do i see silent mode. It is set for , high vibrate/ring. I pushed one button last night while sleeping, don't know what I did, but...
go to settings -> sounds-> volume-> advanced and then scroll down and make sure all of them say "use ringer volume"...if all of them do, then did you try the volume buttons on the side?
Feb 25, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
1,037 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
