Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
I have a 57" 57F500. It will not stay on
When I turn it on the screen is white. I can here what ever is on but not see it. After a few seconds the TV turns of. No power
Can you help
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
Hope it may help you;
Regards;
VOTIT
Posted on Jan 30, 2009
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv screen is red with white vertical lines stays on for a few seconds then turns off
your red CRT is shorted, please respond to this same post with the model number of your set and I will assist you with your problem.
Sep 26, 2008 | Televison & Video
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
150 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
