1994 Honda Prelude Logo
Posted on Jan 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery pulse came off while driving now my care won't start 94" Honda Prelude
Anonymous
Level 2:
New Friend:
  • Expert 166 Answers
  • Posted on Jan 28, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
166
Questions
Helped
35004
Points
470
That meens your alternator is bad
5 Related Answers
Anonymous
  • Posted on Dec 28, 2008
SOURCE: where is the electric fuel pump on a 1993-94 honda prelude s
it behind your back seat under the carpet in the trunk. it comes right out after removing some bolts and screws...
daves944
Dave C
  • 1050 Answers
  • Posted on Feb 19, 2010
SOURCE: 1997 Honda Prelude 177K. I have done the
Unfortunately you probably need a new distributor. There are three pick-up coils mounted down inside the base of it. They go bad quite commonly. The unfortunate part is; the new distributor will come with a new cap, rotor, coil and module...which you have already bought. The distributors are not that expensive though, maybe you can sell the extra parts???
Anonymous
  • 1796 Answers
  • Posted on Feb 16, 2011
SOURCE: how to remove and install the driver side window
Hi!!
Here is how:
REMOVAL & INSTALLATION
See Figures 1, 2, 3, 4, 5 and 6
  1. Remove the door pad and inner moisture barrier.
  2. If working on the rear window of a sedan, remove the two upper screws securing the center channel. Remove the two lower bolts (in the door) securing the channel and remove it. On some cars, the two screws are concealed below the weatherstrip.
  3. For sedan rear doors, remove the quarter glass. The entire glass and rubber seal may be removed as an assembly from the door.
  4. Lower the door glass until the glass mounting bolts are accessible. One will be easily seen in the large access hole in the door; the other will appear in the smaller, round access hole. Remove the bolts.
  5. Stand next to the inside of the door. Tilt the door glass and remove it through the slot.
  6. On front doors, remove the bolts securing the front run channel, then remove the channel.
  7. Remove the regulator mounting bolts and remove the regulator. On later models, there are additional roller guide bolts to be removed. Mark the roller guide mounting bolts to ease window alignment later.
  8. For power windows, remove the motor from the regulator if desired.
CAUTION The regulator gear will move suddenly when the motor is removed due to action of the large spring. Keep hands well clear.
TO INSTALL, REVERSE DIRECTIONS
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Anonymous
  • 118 Answers
  • Posted on Feb 23, 2011
SOURCE: i need the diagram for
Check your owners manual since many manuals include fuse diagrams. Also auto parts stores offer free assistance with repairs and are likely to have diagrams.
clifford224
Clifford Beard
  • 1975 Answers
  • Posted on Jun 01, 2011
SOURCE: my 1995 honda accord cranks but won't start
Does it seem to be tempreture related. i had a cutomers vehicle for almost 2 weeks and it started everytime. The thing was it was inside the garage. Finally one day I had pulled it out into the sun and when i went to put it back in, at that point it didn't start. It was a Honda but don't remember the year but it was around a 1995 like yours. It eneded up being the PGMFI relay wich would cause the exact sysmtoms that you are talking about. I have found out since then that this is a common problem. Give that a shot. I hope this helps and good luck.
1helpful
I have a 94 honda civic ex and it's having
I would have the ignition switch checked, not the key switch but whats behind the key switch. Ignition Switch!
2answers
I have a 1990 honda prelude 4ws it won't start
it is carburetored sounds to be the choke on it
1989 honda prelude check engine light on and won't hold charge
change the battery cables terminals you can get them at walmart for under 5 bucks last time I checked
1994 Honda Prelude si starting problems
Your starter motor is either not getting power or in need of replacement. Otherwise, there is nothing wrong with your car.
Also check your battery connections for no corrosion there as well as by the starter motor. Low voltage circuits in a car are extremely vulnerable to poor contact issues.
94 volvo 960 wagon engine turns over but it won't
have you check for injector pulse? if no pulse or no ignition fire, most likely it is the ECM.
My 93 prelude won't start i change the fuel pump i check my fuses so what now i need help
You will have to see if your getting spark and fuel. If your getting both it should be starting either timing or injector pulse isn't working maybe. If your not getting spark, you will need to check your ignition system. If your still not getting fuel then you have a relay or maybe a computer problem. This isn't exact but a short list of what to check so you can reply with more information.
2helpful
1992 prelude si - battery/alternator prob?
if you can charge the battery and drive it for a while then sounds like the altenator has failed and is not re-charging the battery, good way to test is to charge the battery, start the car and turn the light on, if everything is dimm or the motor dies there is little to no charge voltage, and will require altenator work
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
