Question about ASUS Eee PC 900 Notebook
Ice Cube Size adjustmentsLG SXS Refrigerator. Model GR-L-207 DVZA
I have the above model fridge but now find the ice cubes it makes are too big for the despatch worm to handle - is there anyone who can advise how it is possible to adjust/reduce the water content into the ice making mould to reduce the size of the ice blocks. Thanks in advance.
  • rog_birkin Jan 30, 2009
    Sorry folks but appear to have posted this in the wrong department (and dunno how to re-post it - sorry !)
    President:
  • 2,559 Answers
If you pull the front cover off the ice maker,You will see an adjustment srew with + and - symbol ,just turn that srew.
Please rate this a fixya
Posted on Jan 30, 2009
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
Dec 04, 2017 | Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
Ice does not dispense from whirlpool refrigerator. Model # ED25PQ If you press with a cup or glass to attempt to get ice whether it's cube or crushed there is no noise or ice being sifted through.
Check the ice cube container to see if it is full of cubes and also that the cubes are nor "bridged" above the dispenser auger. Hope this helps!
May 30, 2011 | Whirlpool Refrigerators
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
I have an lg model=gr-l206cvqa fridge freezer, the ice box keeps freezing solid into one big lump of ice
Ice cube tray needs to be replaced if you are referring to the ice bucket area freezing all up. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Refrigerators
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
ASUS Eee PC 900 Notebook Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
