Question about Dell Inspiron 1200 Notebook
Boot from a USB drive
OK fellas, heres my problem. I have a Dell Inspiron 1200 running WinXP Home SP3. I have connected a 80 G USB drive and cloned the internal drive to it using Acronis True Image. I want to replace the origional internal 40G drive with an 80G drive and reclone the new 80G drive. But WinXP dont allow one to do that because upon boot, it closes all the USB ports. So how do I go about getting this thing to boot from the USB drive so I can install and clone a new internal 80G drive?
    President:
  • 2,559 Answers
Go here and follow the instructions
Please rate this a fixya
Posted on Jan 30, 2009
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Touchpad doesnt work anymore. i have just bought a new laptop dell inspiron 1545. it had windows 7 home premium and i couldnt connect it to the domain, so installed winxp sp3, i have reinstalled the...
for this i tellu that you are having problem with your QuickSet driver.... its either not installed or else.. please check the above driver.. If you are not having this.. just go to http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs enter your laptop service tag and download the above driver.. thanx!
Feb 22, 2011 | Dell Inspiron 1545 Notebook
I want to put in new hard drive e1505
i am assuming that your current hard drive is working, you just want to replace it with a bigger one.
you will need two things 1) a way to connect your new hd to your system (such as an external usb enclosure)
2) the software to properly clone the disk image and put it onto a new drive
go onto google and search "clone hard drive" you will find numerous free (or free for 14 days so you can do this before they expire) programs that can do this
here a few links with more details (plus links to the software)
http://labnol.blogspot.com/2006/08/clone-hard-drive-with-free-disk.html
http://www.makeuseof.com/tag/5-ways-to-clone-and-copy-your-hard-drive/
Oct 20, 2010 | Dell Inspiron E1505 Notebook
My usb ports dont work on my dell inspiron 530s, front or rear, key board and mouse not detected.I can't get to desktop
Hi there.. i just got the same scenario when i reformatted mine.
Here's how i solved it:
1 - im using winxp and used restore cd to format it then i install winxp sp3 patch.
2 - download and install latest drivers of my devices from website.
3 - install anti-virus and other software. good to go.
Oct 20, 2009 | Dell Inspiron 530s Desktop Computer...
Inspiron 1200
Sounds Like a Bad Harddrive. First try to Format it out or even Better, Delete the Partition if you can. Then Go With the Fresh Install. Hope This Helps!...
Feb 10, 2009 | Dell Inspiron 1200 Notebook
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
How to disabled the USB port of DELL inspiron 1200?
USB ports can be disabled in the bios.
Robert
Sep 21, 2008 | Dell Inspiron 1200 Notebook
MyBook 500GB Home Ed hangs WinXP SP2 boot up process
Thanks to Guest above. I was having the issue with USB of my WD drives causing the system to hang upon boot up. Disabling USB Legacy did the trick. It's only my WD externals that were causing me the issue but no mor
Jan 24, 2008 | Western Digital My Book Essential Edition...
Windows XP Pro installed but computer boots to Home Edition
It sure is possible.
I would take it back to them and demand that WINXP Pro is put back in there and it boot correctly
They saved about 50 bucks putting in WINXP Home.
Sounds like a bunch of rookies trying to pull a fast one.
Nov 13, 2007 | Microsoft Windows XP Professional for PC
Dell Inspiron 1200 Notebook Logo
600 people viewed this question
Alun Cox
