Question about Philips VR750 VHS VCR
Connection which scart and leads where ?
Lcd tv philipshrdr3700 dvdr alba vhs hq vidio hdmi lead and scart leads please keep it simple michaeljg
2 Suggested Answers
Mark_Webber
  • 472 Answers
SOURCE: Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Posted on Apr 14, 2008
Grubhead
  • 4585 Answers
SOURCE: we live in france so we have got sattelite tv.The
I am a bit confused? A vcr will only need the aerial to pick up signals for TV signals broadcast by a transmitter. As long as the vcr has two scart sockets you can connect your TV to AV1 and the sat box to AV2 and it should record the sat picture and you can watch it by switching your TV to the AV channel. Of course the video will only be any good to record things from sat if your out or in bed. Because you can't watch one channel, record another with the vcr.
I suggest you have a word with your sat company about the record a program service or provide you with a multi room service so you can record channels whilst viewing others.
Posted on Oct 14, 2009
Connecting VCR ,cable box, TV
First connect the cable box to TV using HD-cable (if connection available) or component cable (three leads) observing the colors. Connect cable box to VCR with an S-video cable or SCART if you have an S-video out scart. Connect VCR to TV with another S-video cable (round connectors) or with a scart to an S-video in scart connection. If you are in the US, the scart connections don't apply.
Sep 30, 2013 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a sony SLV-SE730 will not show any picture on my Brava Tv set does it matter what scart lead i use
First of all scart leads are notorious for bad connections. The pins can get pushed flat and not make contact. Look carefully at the connections at both ends of video and TV. Sometimes moving the socket while in the back of the TV/video will spring it into life. You can get higher quality gold platted leads if your old one plays up like this. Most TV's will have a dedicated socket for the VCR, the other being for satellite etc. In most cases it will say just below the socket. Otherwise try AV1 first.
Feb 14, 2013 | Sony SLV-SE730 VHS VCR
Can't tune Alba 7395 VCR into a Goodmans GDB12XIT Freeview box
Has the box got a scart socket? If it has connect the VCR to that via a scart lead. If the alba has two scart sockets then use the second one. When recording set the channel as AV1 or AV2.
If you don't have enough scart sockets to connect your TV, VCR and Box, then get one of these Scart Switching Box from places such as Amazon or Argos.
Jan 14, 2013 | VCRs
Toshiba sd-v295 tunerless DVD VCR Combo To Sony Digital TV Instructions
It will depend on if the Toshiba has an HDMI socket. If it has then the Sony TV will almost certanily have one. Then all you need do is get a HDMI lead and connect the two. The only other way would be via a SCART lead. If the TV has only one SCART and it's being used you can get a SCART Switching Box from places such as Amazon, where you will also get the other cables.
Dec 15, 2012 | Toshiba SD-V295 Tunerless DVD VCR Combo...
I am trying to connect my vcr to my tv and am having many problems. does the vcr need cable? or can it conect solely to a tv? thanks.
If the TV has a scart socket then you should be able to connect it via a scart lead to TV from the VCR. Apart from feeding an aerial lead to the VCR first then out from it to the TV aerial socket it should work fine.
Aug 09, 2011 | RCA VR349 VHS VCR
How do i connect the vcr to the tv so it records on the channel i want. i tried recording but was a different channel. i do not have the remote for the vcr
If the TV has a scart socket and the vcr also, you can connect it that way, with a scart lead. Then all you need do is press the channel button on the VCR till it reads AV. There may be more than one AV socket so use the one with the connection of the scart lead, it should say on the scart socket what it is. IE: AV1. All you need do is set the channel on the TV you want to record, the press record.
You won't be able to watch another channel though while recording.
Some TV's with multi scart have options for AV settings or recording from the TV, so check these out.
Consider buying a universal remote.
Feb 11, 2010 | Emerson EWV603 VHS VCR
How do I tune my sanyo 768 E VHS recorder to the AV channel, so I can record from a freeview box, please?
Has the Sanyo got a scart socket? You would get a much better picture connecting the freeview box to that. You can also get a switching box so you can connect all the things up to your tv with just one scart lead to the switching box. See image below (from Amazon). The buttons switch between the scarts so you can record from scart to scart.
Jan 21, 2010 | VCRs
How to plug vhs to vhs recorder
If they have a scart sockets simple connect them together viva a scart lead. Set one in play and on the other press the av button, select the socket the playback vcr is plugged into and you should see the picture. If you want to record it press the record button.
Ideally the none playback vcr should have two scart sockets. One connected to the TV and the other to the playback vcr.
Oct 04, 2009 | Panasonic VCRs
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi VCRs
Nutshell time:
So..
Apr 14, 2008 | Philips VR550 VHS VCR
Philips VR750 VHS VCR Logo
27 people viewed this question
Top Philips VCRs Experts
Robert McClure
 Grubhead
Grubhead
Are you a Philips VCR Expert? Answer questions, earn points and help others
