Question about Astoria Argenta SAE/JUN Espresso Machine
Will not dispense water
I have aastoria sae1 gets hot makes steam but will not dispense water
  • 22 Answers
If you're pump is working and your needle shows around 9 bars when running, most likely your Solenoid valve is bad. This can be caused from improper backflushing among other things.
We stock them ($60). Email me at fixya@kaldi.com with your contact information or from our website www.kaldi.com
Alex
Posted on Feb 13, 2009
When you press the coffee button the machine grinds the beans, but then the water comes out the steam wand... please help
The problem is a very frequent one a small scale part have been moved and it stack to the water steam valve and it blocking it from closing completely. So when you make coffee the hose of water for coffee is in parallel with hot water steam wand and since the valve remains partially opened the water for coffee find easy escape from steam wand.
So we suggest to perform one more descale and it may need twice hopefully this small scale part to be dissolve a little bit more in order to pass thought the steam valve and thus the valve can close again completely. If you are not so lucky the part remain on the valve then only solution is to disassemble the machine thus clean the steam valve manually. In this solution you may find out that the valve o ring might be damage and thus the leak.
here is the link with steam valve parts and this the parts diagram of the machine and here many more for your machine
Aug 15, 2011 | Saeco Magic Comfort Plus Espresso Machine
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
My coffee machine cva610 says descale expel air. It won't allow me to make any more coffee.
If you don't have a manual I hope this helps. You can make coffee without "Descale"ing it but it is recommended you don't go too long without doing it.
- Make sure that the filled water container is in the appliance.
- Turn the program selector to "On" with lighting and place a container under the hot water spout and another under the steam spout.
- Press the hot water button, turn the steam selector counterclockwise and dispense hot water until it flows in quiet, continuous streams.
- Press the hot water button again. Turn the steam selector clockwise to o, to turn off the water.
Regards,
Dave - Avalonxls at att dot net
Feb 09, 2011 | Miele CVA610
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
Miele CVA610 error reads expel air but when we do as manual suggests (run hot water & milk frother) no water comes out.
If this doesn't do it for you, you are doing it wrong!
Oct 06, 2009 | Miele CVA610
Seaceo magic delux. Steam nozzle gives water and steam (just about) the machine makes a very loud drilling noise while trying to serve the coffee. Coffee is ground and moist when put in dispenser as it...
Please explain problem better. Whats this " just about " when you describe water and steam. Also on this cut off point that machine is getting hot . This machine gets hot normally , there is a heat cut off mounted on boiler but you would have to remove top off machine and physically check which I don't think you did.
Aug 06, 2009 | Saeco Magic De Luxe Espresso Machine
Water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
Apr 11, 2009 | Nuova Simonelli JAZZ Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Astoria Argenta SAE/JUN Espresso Machine Logo
753 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
