Question about Singer 7442 Mechanical Sewing Machine
Bobbin filling My bobbin won't fill. My machine is operating fine except that when i want to fill the bobbin, the mechanism won't turn to fill the bobbin (on the top of the machine) Has anyone else had this problem?
  • Anonymous Feb 13, 2009
    I have the same problem with my Kenmore.  It is an old machine, but sews just fine, lately can't get the bobbin filled.  I had to fill the bobbin by hand
  • Anonymous Mar 31, 2014
    Bobbin won't fill
    New Friend:
  • 186 Answers
Does the winder spin freely by hand? If so then it needs to be adjusted, maybe a new bobbin tire also. If not then try oiling it and freeing it up by hand.
Hope this helps.
Posted on Jan 31, 2009
Why won't bobbin winder automatically shut off when filled?
Probably something within the bobbin winding mechanism is misaligned or broken. You can probably still wind bobbins except you will probably need to slow it down, watch it, and stop the winding action when the bobbin gets near the filled capacity. Or, for ~$35, you can purchase a standalone bobbin winder (one brand name is Sidewinder) from JoAnn's, Hancocks, or even Amazon.com. (Also helps save wear and tear on your machine.)
Dec 29, 2015 | Sewing Machines
Can`t rewind bobbin
Sounds like it may be a bad solenoid or clutch inside. When it tries to reverse direction to rewind is sounds like it's getting stuck. The lights comming on might be an indication that the machine detects a problem. You could try to open it and see if any of the gears are broken or out of place or if any of the teeth on the gears are missing. But I would get it serviced if you're not comfortable with opening it up.
Jan 18, 2008 | Singer 7442 Mechanical Sewing Machine
When I try to fill my bobbin the thread gets all balled up on top of the bobbin instead of filling it. What should I do?
Consult your owner's manual. Chances are you may be threading the thread incorrectly. Make sure it is going through the bobbin winder tension guide before going to the bobbin winder mechanism.
If it continues, the bobbin winder may need a height adjustment. I had that issue with a machine that the case surrounding the bobbin mechanism was slightly misaligned. Once it was fixed, the bobbin winder worked perfectly.
Dec 01, 2015 | Sewing Machines
Can't fill the bobbin! Starts ok, but immediately stops and beeps.
Is it the correct bobbin? Is it wound in the correct direction? Is the tension set for the type of thread?
Jan 22, 2015 | Singer Confidence 7467 Mechanical Sewing...
Singer 7258 bobbin filling issues
If it is new, it is defective, return it for service or replacement.
Mar 23, 2014 | Singer 7462 Mechanical Sewing Machine
Brother NX400 SEWING MACHINE after changeing thread top and bottom it now makes a nocking noise?
try rethreading the machine again, make sure to use every thread
guide
make sure to not over fill the bobbin
make sure the bobbin is inserted correctly into the bobbin
case, this is very important
make sure the bobbin is turned the correct way in the bobbin case
the machine won't work right if the bobbin is not turned the right
way
clean under the needle plate and in the bobbin area for lint
Nov 02, 2012 | Sewing Machines
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
Bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
May 31, 2008 | White Sewing 2999 Mechanical Sewing...
Singer 7442 Mechanical Sewing Machine Logo
388 people viewed this question
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
